Best Bulbs for Stock Housing - Mustang Evolution
Old 12-19-2011, 09:31 PM   #1
GTtopgear's Avatar
Any thoughts on what the brightest and whitest bulbs you can buy for the stock housing headlights would be?
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 12-19-2011, 09:33 PM   #2
Las0mbra's Avatar
Hids... If you didn't want to go that route though, silvania silverstars I believe are the brightest around.
Old 12-19-2011, 11:52 PM   #3
GTtopgear's Avatar
I did do hid's. Burned right threw the housing. Went back to stock. I seen the silverstars but they come in different varieties. Witch one should be the best fit?
Old 12-20-2011, 12:19 AM   #4
Las0mbra's Avatar
I have no idea... Honestly I would just go to autozone or something similar and ask them to look it up, put it in there once you get it and if it's the wrong size, return it.
Old 12-20-2011, 01:15 AM   #5
Burkeys96GT's Avatar
Re: Best Bulbs for Stock Housing
silvania silverstar ultras and i believe it is a 9007 bulb
Burkeys96GT is offline   Reply With Quote
Old 12-20-2011, 02:52 AM   #6
what HIDs were you running to burn through our housings...i've had 3 mustangs now all running HIDs including one that ran 55w headlights and 55w foglights...i have a feeling the brand you chose played a huge roll in what happened...
might i suggest you check out DDMtuning.com for a quality set of HIDs for under $50
SonicBoom239 is offline   Reply With Quote
Old 12-20-2011, 06:58 AM   #7
Las0mbra's Avatar
+1. I got these, but I have 35watts. Really bright and with shipping, they were $65
Old 12-21-2011, 12:47 AM   #8
and right now the single beam kits are $30 in 35w
Thermostat Housing Tj88mustang 1979-1995 Mustang GT 8 11-27-2011 08:38 PM
black headlights housing 82stang224 1979-1995 Mustang GT 7 09-20-2011 02:54 PM
HID in reflector housing mickeyp49 2011-2014 V6 Mustang 14 07-21-2011 01:49 PM
07:02 AM
