My 96 GT's clutch went out. I think. - Mustang Evolution
Old 12-19-2011, 10:24 PM   #1
Mustang_Madness's Avatar
I know its a cable clutch line but i dont know if thats whats done it. Everytime i turn the car on, i cant shift out or into any gear, and ill have the clutch down All the way. There is still alot of pressure
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 12-19-2011, 10:42 PM   #2
deadsp0t's Avatar
If the pedal is still firm then the cable is fine, it may need to be adjusted. Which can be done under the car where the cable connects to the shift fork on the drivers side of the bell housing. The cable may already be adjusted all the way out, in that case you maybe can just replace the cable which is fairly easy and cheap. If you end up just needing the cable I advise you to get an aluminum quadrant to replace the stock plastic one which is very weak, and add a firewall adjuster so you don't have to get under the car to make clutch adjustments.
That's unimpressive
Old 12-19-2011, 10:54 PM   #3
What kind of adjustments can be made then? Like the pressure of the clutch or what? I assume have a cable for a clutch "line" is alot easier to manipulate than an actual fluid line..
Old 12-19-2011, 11:01 PM   #4
deadsp0t's Avatar
Free play adjustment is all you can do. Does the pedal have a little free play or a lot? If its only a little free play you may have a transmission issue. If you have a lot of free play/slack in the pedal the clutch is not fully releasing and thus not allowing you to change gears. If you have close to no free play in the pedal you may have an issue with the synchronizers in the tranny.
That's unimpressive
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
Clutch eouellette18 2005-2010 Mustang GT 9 09-08-2011 03:51 PM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Clutch? :( nickysixx 1996-2004 Mustang GT 5 07-08-2011 04:13 PM
12:32 AM
