Eldebrock efi - Mustang Evolution
Old 12-20-2011, 09:26 AM   #1
Burkeys96GT's Avatar
Eldebrock efi
Have a friend who is doing the eldebrock efi setup and is just doing the mani plenum and tb stock maf fuel injectors and everything will this work properly
Burkeys96GT is offline   Reply With Quote
Old 12-21-2011, 01:44 PM   #2
Re: Eldebrock efi
yea...he just useing the mmr plate and going to run his planum and throttle body? he knows he needs to use the rails or the mmr rails also the fitting to adapt your frps from mmr also.. or from aeromotive..
when installed should run just fine..
slow02gt is offline   Reply With Quote
Old 12-21-2011, 05:51 PM   #3
What size injectors should he run with this setup
---------- Post added at 07:51 PM ---------- Previous post was at 07:42 PM ----------
He has the intake mani the 90mm plenum the 90mm tb and the fuel rails what size injectors should he use
Old 12-21-2011, 07:10 PM   #4
Re: Eldebrock efi
so he is going to run the wilson or 6061 plenum?
stock injectors will be fine...its not like he is bolting on 100hp..
he knows if he is acutally using the fox 90mm tb he will need to change the throttle cable to the fox 1 also? along with a few other little things?
atomic efi dreamstang General Mustang Discussion 4 11-05-2011 07:01 PM
Victor jr efi spyder intake Cm644rodrigues 1979-1995 Mustang GT 4 10-18-2011 11:40 PM
Carb vs efi Mustanglife General Mustang Discussion 2 07-06-2011 06:23 PM
12:49 AM
