How make 350-400 rwhp N/A - Mustang Evolution
Old 12-21-2011, 01:53 PM   #1
Dgibson's Avatar
Is it possible? How can I do it? What mods? And how much cash we talking. On 98 gt 4.6
names doug!
im 21 about to 22. i live in southern indiana. im in the indiana army national guard and i deployed to iraq in 2011.i drive a 1998 gt black and silver. i love playing soft ball,riding four wheelers,crotch rockets and anything to do with cars.
Dgibson is offline   Reply With Quote
Old 12-21-2011, 01:59 PM   #2
236mustang's Avatar
Re: How make 350-400 rwhp N/A
Stroker kit, p/p heads and intakes and cams
But still don't know if that's enough to make 350rwhp
1995 Cammed/Turboed V6 Mustang (auto)
13.3@103mph
Built by Iron Horse Motorsports
236mustang is offline   Reply With Quote
Old 12-21-2011, 02:06 PM   #3
CodyNelson's Avatar
Region: West Virgina
Trick flow top end kit. Get the higher compression kit. You will also need a pi (99-04) intake manifold. That plus full bolt ons and a tune will give you about 380
---------- Post added at 04:06 PM ---------- Previous post was at 04:05 PM ----------
Mmr also sells port and polished TFS heads. A set of those with some real aggressive cams should put you at or a little over 400
Old 12-21-2011, 02:14 PM   #4
Rapinator126's Avatar
Your not going to make that much.
Old 12-21-2011, 02:20 PM   #5
Mile high JDF's Avatar
+1 aim for a 10.5:1 compression ratio with a solid stroker kit and you'll make it
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-21-2011, 02:27 PM   #6
Not likely man 400 i do not see that hapen.
Old 12-21-2011, 02:29 PM   #7
Why is that?
Old 12-21-2011, 02:29 PM   #8
DaBluedude's Avatar
I've been looking into this for years. Not gonna happen realisticaly. Either do a swap or blow it. Way cheaper, easier, and streetable.
2003 Mach 1
Old 12-21-2011, 02:35 PM   #9
CodyNelson's Avatar
You can. A guy in my area has the TFS top end kit with full bolt ons and made 378
---------- Post added at 04:35 PM ---------- Previous post was at 04:34 PM ----------
I feel like we have had this same convo before lol
Old 12-21-2011, 02:48 PM   #10
Dgibson's Avatar
I wanna stay N/A I don't wanna get into a blower or anything. I don't wanna blow it seeing how it's stock block right now. My plan now is CAI,throttle body,HCI,L/T headers already have O/R x pipe and flow master exhaust. And a short throw shifter is my list for now
names doug!
Old 12-21-2011, 02:51 PM   #11
Eturner's Avatar
SHM has a build that will put about 360hp at the wheels!...
Old 12-21-2011, 02:54 PM   #12
Dgibson's Avatar
Who?
names doug!
Old 12-21-2011, 03:00 PM   #13
Eturner's Avatar
Originally Posted by Dgibson
Who?
Sean Highland Motorsports!..
Old 12-21-2011, 03:07 PM   #14
Dgibson's Avatar
What's it run ya $$$
names doug!
Old 12-21-2011, 04:00 PM   #15
Eturner's Avatar
Not sure about that!... You'll have to look it up!... But I do have a book that he wrote a couple years, and it tells ya about how much power you should see!... It's all on the 4.6L 2v, 3v, and 4v mod motors!..
Old 12-21-2011, 04:13 PM   #16
Dgibson's Avatar
I sent them an email and ask how I could make what I want so we will see what they say
names doug!
Old 12-21-2011, 04:37 PM   #17
504 Stang Rida's Avatar
My friend just got his 04 GT back from the shop and he make 407 horses he got the MMR stage 3 ported trick flow heads, stage 3 cams, merize electric water pump, k&n c.a.i, trick flow intake manifold, & 42lb fuel injectors so its possible but he also dropped over 7k on all of this
504 Stang Rida is offline   Reply With Quote
Old 12-21-2011, 04:48 PM   #18
Eturner's Avatar
Is his car na??... And how does he like that water pump??... I've looked into those and I'm kinda unsure about it for a DD!!....
Old 12-21-2011, 07:06 PM   #19
bull sh#t..
unless its a big bore stroker with 12:1 compression and spinning it 7500 rpms he did not sorry..
350 is fairly easy..anything over is a hassle..
you will need 11:5:1 or higher,light rotating assembly(stock crank prepped, i beams,good pistons)..for a all n/a motor you dont to spend money on a forged crank as they are heavier, dont need ported trickflow heads, some out the box trickflows cleaned up or some great ported pi heads,custom spec'd cams with some decent duration, eddy or trickflow intake(eddy with a 60601 and 90mm and jlt, trickflow(big single blade tb or dual) and some nice rpms behind it..but you can acutally get close to 350 with the stock pi intake.
---------- Post added at 08:06 PM ---------- Previous post was at 08:00 PM ----------
and to make over 400 it will be easier on a 2v to go eddy intake and a carb..
cprblue on corral made like 420 or so with his 2v..but compression is 12:1.race ported trickflow heads from rick at foxlake,acutally had some off the shelf comp 278s, eddy intake with carb,i beam rods,(forgot what pistons) stock race prepped stock crank(for light weight and decent rpms) and e85..
slow02gt is offline   Reply With Quote
Old 12-21-2011, 07:22 PM   #20
Originally Posted by slow02gt
bull sh#t..
True!! The motor my cousin had b4 he lost oil presure and locked up on him. 4.6 2v. Fully built. Heads cams 11:1. The works everything. Made 315 at tires. Now he has a 5.4 bored to a 5.7 and carbed with a 150 shot.
Old 12-21-2011, 07:26 PM   #21
Dgibson's Avatar
I'm not looking for a freaking super drag car I want up around 350 N/A that's it should be easy with enough mods I don't wanna put nitrous blower turbo cause I'm not rich and can't afford to build a complete motor just yet it's my DD
names doug!
Old 12-21-2011, 07:31 PM   #22
It will cost u quite a bit. Cousin had fully forged rotating assembly 11:1 compresion heads/cams/intake. All trickflow and every other dam bolton u can do/full exhaust and like i said made 315 at tires. U be better just puting a supercharger on it cost u less than spending all the dam money on trying to get to that hp na. And still fall short.
Old 12-21-2011, 07:41 PM   #23
Dgibson's Avatar
If I throw a supercharge it and run the all stock motor I have now kaboom goes that and I'm walking everywhere! So I might as well stay stock or buy an ls1 and I don't make 350 oh well at least I'm closer to having a built motor and then I can forge and put a turbo on it. I've seen like 3 threads on here of guys with a ruined motor over FI stuff
names doug!
Old 12-21-2011, 07:48 PM   #24
U will get around what my cousin got with his maybe a lil more just depends. Dont go the chevy route man lol.
Old 12-21-2011, 07:50 PM   #25
Dgibson's Avatar
Making power with an ls is like taking a **** it's simple bolt on and some tuning! I just don't wanna get ran on by everything so maybe I should say I want over 300 NA
names doug!
Old 12-21-2011, 07:55 PM   #26
U will get close to your goal of 350 man just got to up the compresion and all i said earlier. Its posible u can make more than the 315 my cousin had he had a ****ty tune done. So u can get close to your goal maybe 335 around there with a dam good tune. Then after that throw a procharger or whipple on there and u be more than happy. Just takes time. And i lnow chevy motors make power go check out my uncle fox on my profile gots a chevy motor in it lol and procharged made 1200
Old 12-21-2011, 08:05 PM   #27
Dgibson's Avatar
In my town you have to step up to the plate and swing hard hard or stay in the garage we have a 2jz supra Oisin 1100 and it's on the street I just don't wanna get. My *** hammered everytime 350 NA is my goal till I can forge my internals
names doug!
Old 12-21-2011, 08:09 PM   #28
Brett Greene's Avatar
My fully built 347 made 400 rwhp NA
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 12-21-2011, 08:12 PM   #29
Much respect to u then man. I was just trying to help out thats what everyone here for. Wasnt trying to say what u cant do. Was trying to tell u whats reasonable
Old 12-21-2011, 08:27 PM   #30
Dgibson's Avatar
I know bub I'm not mad or anything just this car is frustrating me
names doug!
Old 12-21-2011, 08:32 PM   #31
To be honest. If you wanna make any kind of power your going down a longgg road my friend. Lots of hard work, frustration and money to be spent. I have spent well over 40,000 in just mods to my mustangs. I will tell you from experience it's not worth the money. Buy a car with alllllllll the work done already.
Old 12-21-2011, 08:51 PM   #32
It will be worth it if thats what he truely loves. personaly i will spend whatever it takes to meet my goals and i have with every stang ive owned so far. In the process of doing a fullybuilt motor with f1r procharger to my 427r now.
Old 12-21-2011, 08:53 PM   #33
Just my advice. My 95 has over 22 000 into it. Might be worth 15000 if I were to sell
Old 12-21-2011, 08:54 PM   #34
Thats the only downfall we will never get the money we put in our cars back out of it.
Old 12-21-2011, 08:55 PM   #35
Yup. I'll have this car until the day I die.
How to build a 400 RWHP V6 Mustang Trojan Horse 2011-2014 V6 Mustang 12 09-01-2011 06:41 AM
11:40 PM
