Engine removal, rebuild progress - Mustang Evolution
Old 12-21-2011, 05:01 PM   #1
vettekiller's Avatar
well , I'm pulling my 4.6 out of my 2002 mustang GT. I had a slight knock , I'm assuming a rod bearing. I'm going to beef it up a little and throw a set of cams in with some forged internals. I am by no means a mechanic , so this will be the most challenging thing I've ever done , so when I ask dumb questions don't laugh :/
vettekiller is offline   Reply With Quote
Old 12-21-2011, 05:13 PM   #2
I got the TB, intake and wiring harness off the top. I am working underneath tomm. I started to try and take off the steering pump , but the bottom line is tight as hell. hopefully get that off and a/c compressor off with the rest of the wiring tomm. I'm planning on pulling motor and tranny together.
Old 12-21-2011, 05:25 PM   #3
hey just some thought.
when i take something apart i use ziplock bags perferably with the white srtipe to mark them.and i bag all the bolts for each part seperatly.
stay organized .dont get in a hurry and start tossing parts everywhere.especially if its gonna take a while.when u go to put it back together its a pita to find everything when this happen.
its also a good idea to mark you wiring harnesses so u know where each one goes back.
these are just a few things i do when i tear something apart and i know theres a chance i may not remember where everything goes
good luck on your project
Old 12-21-2011, 05:37 PM   #4
thanks , I think I read on here to do that , so I did. I am staying really organized for a easy install. i like taking things apart from above , it's underneath I hate ..
Old 12-21-2011, 05:41 PM   #5
johnnybebad's Avatar
I don't know if you are out of a/c coolant, but heads up if your not that stuff is going blow right in your face (happened to me when I did it) lol. I recommend glasses and gloves. Good luck.
johnnybebad is offline   Reply With Quote
Old 12-21-2011, 05:49 PM   #6
when I take the compressor off ? cause that's on the books for tomm. did you have a hard time getting the power steering pump off ?
Old 12-21-2011, 06:10 PM   #7
Yep I was referring to the compressor. Sorry I have never pulled my engine out I may need to down the road 167000 miles on my big blue =-/ but I have ripped out my full a/c to save some weight and hp. So I really couldn't tell about the power steering but it seems straight forward
Old 12-21-2011, 06:20 PM   #8
oh , well thanks for the heads up on the compressor
Old 12-21-2011, 06:57 PM   #9
BayyGT's Avatar
Power steering is the biggest pita in the world. One of the bolts can only be loosened and tightened with a wrench like a quarter of a turn at a time so just be patient with it and you'll get it out. Ac compressor is cake like 3 long bolts and it's off. Good luck. I pulled my engine not to long ago and rebuilt it as well.
BayyGT is offline   Reply With Quote
Old 12-21-2011, 07:19 PM   #10
awesome, how did your build turn out ? any pointers would be greatly appreciated. make sure and follow my thread
Old 12-21-2011, 07:32 PM   #11
onesickstang01's Avatar
3 bolts for ac. Leave compressor hanging. Power steering four bolts leave hanging also. Two big connectors for wiring harness of engine and trans on passenger side firewall so dont have to disconnect everything. Easiest way is have car way up in air and drop entire k member
onesickstang01 is offline   Reply With Quote
Old 12-21-2011, 07:53 PM   #12
what would I hang the steering pump by? do I not have to take that bottom line completely off ? I think the reservoir hose is the only other thing connected to it. or will the bolt about that bottom line cone off without removing the line?
Old 12-21-2011, 08:01 PM   #13
A bungee cord will work. Dont take the line off just wrench it out. Take all other bolts out of it first and it will come down
Old 12-21-2011, 08:11 PM   #14
good , I will do that tomm. I been fighting w that damn line all day. thanks man
Old 12-22-2011, 03:53 PM   #15
got the power steering pump off , and the a/c comp. I know this seems slow but I'm only working on it when I have a spare minute. if I am pulling the tranny and the motor together do I still need to remove the starter ?
Old 12-22-2011, 04:28 PM   #16
86 muscle's Avatar
No, I would but you don't need to, just make sure you disconnect all the wires!
86 muscle is offline   Reply With Quote
Old 12-22-2011, 04:29 PM   #17
Filibuster
+ 100
Also when I remove something ill tread the bolts back where they go...
I.e when I removed the trans I put the bolts back..helps when bolts are different lengths!.
XXSTEVEO66 is offline   Reply With Quote
Old 12-22-2011, 04:30 PM   #18
Filibuster
And its cool you're posting as you go!...good luck with the rebuild!!.
Old 12-22-2011, 04:35 PM   #19
thanks guys . I'm really having a goodtime with this project. should be able to get more done after christmas is out of the way.
I guess I will just leave the starter on then. I will make sure to unhook the wires, I gotta finish unhooking all the tranny lines and stuff too.
Old 12-22-2011, 04:49 PM   #20
Filibuster
Also do you have a haynes or chilton catalog?...they are a real big help!..even when I know how to do something I'll refer to it for the order in which to remove and reinstall!...I notice alot when im over confident in somethin ill skip a step in between so I just open the book to remind me
Old 12-22-2011, 04:52 PM   #21
lol, I don't have one yet, but I am for sure getting one this weekend. ive got to go pick up a engine stand as well.
Old 12-22-2011, 05:19 PM   #22
+1 mine has many greasy pages.lol
Old 12-22-2011, 05:27 PM   #23
Filibuster
Haha yup pages are falling out of mine!..
Old 12-22-2011, 08:47 PM   #24
2002VertGT's Avatar
Subscribed....I wanna see this process unfold so I will know what to expect. Won't need this for a while (only 72k on my baby) but still wanna know!
4.10 Gear/RPM thread
Old 12-23-2011, 11:10 AM   #25
JetLife 01GT's Avatar
+1
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-24-2011, 03:15 PM   #26
edross's Avatar
Re: Engine removal, rebuild progress
94,000 miles on mine, how many miles before it started to knock?
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 12-24-2011, 09:36 PM   #27
141,000
Engine Rebuild Kit form summit kbolden50 1979-1995 Mustang GT 10 09-29-2011 04:34 PM
1999 Mustang GT Engine Rebuild Question!!! FORDGT14 1996-2004 Mustang GT 4 09-26-2011 12:10 PM
Engine rebuild option Travis B 1979-1995 Mustang GT 5 09-25-2011 04:51 PM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
Engine rebuild north of Chicago ? Rewbeez Classic Mustangs 1 07-23-2011 01:10 PM
04:01 PM
