What next: COP or SCT - Mustang Evolution
Old 12-28-2011, 01:04 PM   #1
MustangGT02's Avatar
Ok my car has what sounds to be a misfire but does not have any code, it only pops at idle and it really started after my CAI. So should I buy COPs or try an Bama tuner?
I also just replaced the EGR, I have cleand both the MAF and IAC.
I put the original intake on for a week and the pop was less but still there.
MustangGT02 is offline   Reply With Quote
Old 12-28-2011, 01:23 PM   #2
kickerofdoom's Avatar
Tuner
Old 12-28-2011, 03:27 PM   #3
Re: What next: COP or SCT
Originally Posted by kickerofdoom View Post
Tuner
Can you explane to me how one would help.
Old 12-28-2011, 08:23 PM   #4
Sets air fuel ratio better and you can read codes if any pop up. Datalog to see what the number are and what the engine is doing
Old 12-28-2011, 10:53 PM   #5
02PONY's Avatar
Can u explain the pop u are hearing a little more. Is it when it's idling when u rev. Or. When let off. How loud is it
02PONY is offline   Reply With Quote
Old 12-29-2011, 10:56 AM   #6
The pop is only at idle, and when in gear. It goes away above 1000 rpm. It is a quiet pop and the engine its self twitches when it pops.
Old 12-29-2011, 11:16 AM   #7
change plugs first and it may go away..
slow02gt is offline   Reply With Quote
Old 12-29-2011, 12:43 PM   #8
Already done and I put a new fuel filter on.
Old 12-29-2011, 12:55 PM   #9
02PONY's Avatar
Is defrost on or off or does it do it either way
Old 12-29-2011, 01:59 PM   #10
86 muscle's Avatar
My 2000 GT does the same thing!
I know my 02 f 150 did something kinda similar and it was a vacuum leak but idk about this car
86 muscle is offline   Reply With Quote
Old 12-29-2011, 03:03 PM   #11
A/C on or off it does it.
Old 12-29-2011, 04:23 PM   #12
DarkShadows's Avatar
Do you have a off road xpipe. If so that can cause the sound you speak of, which is normal.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 12-29-2011, 04:39 PM   #13
No the only things not stock is the Cai and catbacks, it all started after the Cai but still does it with stock intake.
Old 12-29-2011, 04:44 PM   #14
86 muscle's Avatar
Does it want to die at idle sometimes?
Old 12-29-2011, 04:46 PM   #15
02PONY's Avatar
Clean the iac and maf just spray don't wipe
Old 12-29-2011, 05:10 PM   #16
Like I said on the original post I already cleaned the Iac and Maf and it has a new Egr
Old 12-29-2011, 05:13 PM   #17
did the cai say anything about requiring tune? alot of them do.i would say get the tuner.worst case scenario u dont get ur problem fixed and end with a good handheld.
Old 12-29-2011, 05:33 PM   #18
Yah that's what I was thinking, the Cai is American muscles and the catbacks are summit racings btw
Old 12-30-2011, 11:28 AM   #19
JetLife 01GT's Avatar
I knw this how nothing to do with the topic of this thread. But how do the summit catbacks sound?
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-30-2011, 11:39 AM   #20
AgentOrange's Avatar
I run AM's CAI with no tune (yet) and it lopes a bit at idle, but no popping, just so you know. I didnt get the loping before the CAI. I had a K&N cone instead of the factory box before.
AgentOrange is offline   Reply With Quote
Old 12-30-2011, 11:42 AM   #21
Yes it does, somethimes it goes to around 400rpms then goes back up, when I replaced the egr it helped a little but it still does it every once and a while.
THey sound great for the price, heres a video of the first week they were on, they sound even better now. Problem is they dont have tips but im pry going to buy these.
http://www.jegs.com/i/Dynomax/289/36484/10002/-1
Heres the video,
Old 12-30-2011, 06:04 PM   #22
94 Mustang GT's Avatar
That wouldn't make a difference! Lol.
---------- Post added at 07:01 PM ---------- Previous post was at 06:59 PM ----------
My 4.6 didn't need a retune with just a cai. Ran great w/o return for 50k before I sold it! Lot actually don't need retune.
---------- Post added at 07:04 PM ---------- Previous post was at 07:01 PM ----------
If you think the COP's are bad unplug each one individually. If engine runs rougher that COP is fine. If engine doesn't run rougher the COP is bad!
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 12-30-2011, 06:15 PM   #23
Yes u are right some don't,but some do.if it started happening after the install there is a good chance that it or something related to the install is the problem.
Old 12-30-2011, 06:50 PM   #24
Well thats what I thought, but after I put the CAI on I took it off and put the original on. It still did it just less noticable.
Old 12-30-2011, 07:35 PM   #25
I have seen may cai installed on MANY different vehicles w/o an issue, but the issue I have seen is too much oil from the cai getting on the maf causing rough running issues.
1994 Mustang GT
Old 12-30-2011, 07:38 PM   #26
86 muscle's Avatar
I just put a tune on mine, and that stopped the rough idle so far.
Old 12-31-2011, 12:33 AM   #27
Just thought of this. Check the intake pipe after the maf to see if there any holes that are open. I had a similar issue with that a while back because the intake had a hole for a intake temp sensor, but the car doesn't have one separate of the maf (mine didn't anyway.) it was pulling in air after the maf which drove the ecu nuts. check that and your vacuum hose connections also.
Old 12-31-2011, 08:35 AM   #28
Brakingbenjamin's Avatar
Xpipe wouldn't make the engine twitch though, the only thing I can think of besides plugs or vacuum is TPS or MAF. While the engine is at idle, pop the hood and tap on the mass air flow sensor, if the engine stutters, it's usually a problem with the MAF, you can get a reman MAF for about $70 or a new one for 280
Brakingbenjamin is offline   Reply With Quote
Old 12-31-2011, 05:48 PM   #29
True, the engine doesnt twitch, It just has a pop in the exhaust note once and awhile.
Old 12-31-2011, 10:22 PM   #30
Well I opened the hood and looked and the engine is running smoother than I thought, I tried to tap the MAF and nothing, could not having the right PCV tube also cause this? (passenger side to the TB tube) Heres the right one,
2001-04 Mustang 4.6L 2V GT Pcv Valve To Upper Intake Hose by Ford at LRS - Same Day Shipping!
Which I will be buying anyway.
Im getting a tuner first, if that doesnt work I will have a good tune and somthing to watch how the car is running so there is no down side to getting one.
SCT 2007 Gt Aggiesrok 2005-2010 Mustang GT 31 12-28-2011 03:24 AM
Sct tuner or diablosport? Pstang5 2011-2014 V6 Mustang 3 12-14-2011 09:02 AM
SCT? back n a stang 2011-2014 Mustang GT 37 10-25-2011 05:19 PM
Any of you guys with SCT Tuners might want to read... illestdomer2005 2011-2014 V6 Mustang 15 09-12-2011 10:03 PM
06:14 PM
