My rear gears... - Mustang Evolution
Old 12-28-2011, 02:12 PM   #1
Cajunick's Avatar
My rear gears...
So.. I did the ole mark the drive shaft turn the wheel one rotation thing. I came up with 3 and 3/4 turns. So it seems to me that I have 3.73 gears. Now my traction control light is always on and both my wheel are pulling full time witch leads me to believe I have a locker in my rear end correct me if I'm wrong? The guy I bought the car from pretty much didn't know crap about it or cars in general. So I'm slowly figuring out everything this car actually has in it. With all that begin said my question is for the guys with 3.73 gears I just want to know what rpm's your turning at 60mph and 70mph. I turn 2k at 60mph and roughly 2300ish at 70mph.
Cajunick is offline   Reply With Quote
Old 12-28-2011, 03:35 PM   #2
93slowstang's Avatar
If your traction control light is on there is a problem with it. It's purpose is to prevent the tires from spinning. Mustangs with an 8.8 come with a traction loc from the factory.
Old 12-28-2011, 03:39 PM   #3
Cajunick's Avatar
Re: My rear gears...
Sorry should of made myself clear. I meant the light on the button not in the dash. The light is always on, on the button I can't turn it off. I'm not bothered by it I thought the 8.8 came with limited slip. Thats why I figured I had a locker.
Old 12-28-2011, 03:47 PM   #4
Ok, got ya.
Old 12-28-2011, 05:07 PM   #5
Mzilla's Avatar
Not sure about the gear got a 4:10 locker with frpp carbon clutch packs but likely if the trac button is always lit it usually means it has been custom tuned and completely shut off in the ecu. I have and Sct 4 position tune switch in my 04 and depending on what tune I'm using the trac will be off. When my wife drives the car I put the car back to normal with trac on and the rev limiters set at 5k haha!!
Mzilla is offline   Reply With Quote
Old 12-28-2011, 05:10 PM   #6
Cajunick's Avatar
Is there any way I can tell If my pcm has a tune on it?
Old 12-28-2011, 05:12 PM   #7
Mzilla's Avatar
Pull the passenger side kick panel and pull the ecu out if the holder and take a look at the door on the end see if it has anything plugged into it or see if it's been tampered with
Old 12-30-2011, 11:19 PM   #8
94 Mustang GT's Avatar
If your diff still had the tag on it, it will say right in the tag what gears you have! Mine says 3L27 which is a locking 3.27
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 12-31-2011, 12:50 AM   #9
ColeJohnson's Avatar
Well not to alarm you or anything.. But with my 2002 GT with a T3650 tranny and 4.10gears in the rear.. I turn 2300rpm at 70-75mph in fifth..
2016 Comp Orange GT (current)
Old 12-31-2011, 09:12 AM   #10
Cajunick's Avatar
Umm not sure what to say about that lol. I counted 3 3/4 turns twice. As far as I know it seems that I have 3.73 but 4.10's would be nice to have with this gas milage lol.
Old 12-31-2011, 09:46 AM   #11
I get roughly 21mpg hwy and 17ish city. Driving conservatively, of course.
Ok...3.55 vs 3.73 vs 4.10 Gears illestdomer2005 2011-2014 V6 Mustang 16 01-17-2015 09:17 PM
Post your highway MPG with rear gears illestdomer2005 2011-2014 V6 Mustang 14 11-10-2011 09:58 AM
Rear Gears: 3.55s or 3.73s? TheJigShow 1996-2004 Mustang GT 5 09-28-2011 12:23 PM
Gears.?.? Mach General Car Discussion 1 08-26-2011 12:02 AM
Any idea of what rear end gears i may have in my 92 GT? macmarine39 1979-1995 Mustang GT 4 07-16-2011 08:25 PM
09:20 PM
