miss in rain? - Mustang Evolution
Old 12-30-2011, 05:39 PM   #1
johnmcillwain's Avatar
miss in rain?
I have a 99 gt that seems to only miss in the rain under a load or lugging any help appreciated. It's an auto. Thx
johnmcillwain is offline   Reply With Quote
Old 12-30-2011, 09:30 PM   #2
Moister it's ur wires
Gtif is offline   Reply With Quote
Old 12-30-2011, 11:11 PM   #3
94 Mustang GT's Avatar
Not sure if you have COP or wires. I know the works for wires so I would think it should have an effect on COP, but spray some salt water one the wires while running. You should see some sparks. It won't do any harm!
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 12-31-2011, 01:46 AM   #4
Re: miss in rain?
4.6 coil over plug. ?
Old 12-31-2011, 04:18 AM   #5
DaBluedude's Avatar
Check ur ignition system, plugs, coils, and actually check ur.valley for antifreeze in case your lower intake manifold gave up.
2003 Mach 1
Old 12-31-2011, 05:26 AM   #6
Re: miss in rain?
Ok Thx will do
Old 12-31-2011, 08:41 AM   #7
Brakingbenjamin's Avatar
Also wd40 will absorb the moisture from the wires
Brakingbenjamin is offline   Reply With Quote
Old 01-02-2012, 10:19 PM   #8
Wd40 is a temporary fix. You can find deals on the forums site
1996 mustang gt miss Rebbew 1996-2004 Mustang GT 6 12-13-2011 07:02 PM
What Im going to do about my bad idle and miss MustangGT02 1996-2004 Mustang GT 2 12-12-2011 06:04 PM
Driving with an aftermarket CAI in the rain? phobik General Mustang Discussion 19 11-23-2011 08:01 PM
Car has miss at idle MustangGT02 1996-2004 Mustang GT 4 11-20-2011 12:19 PM
Miss fire. TylerLawrence Pre-2005 V6 Mustang 8 09-21-2011 07:55 PM
» Members Mustangs
My baby
renouji
Tow rig
Jr79
Add your Mustang
11:54 AM
