Cams for the 02 gt - Mustang Evolution
Old 12-30-2011, 10:26 PM   #1
Cams for the 02 gt
Im starting myresearching on cams but I am new to the 02 popular cams . I know the foxbody loves th E303 cam and that's all I know. So, what's a good set on stock heads valves and springs. I'm not sure if I have a solid roller cam nor do I know the lift or the max( recommend ) lift I can go. I'm 70mm all out with cai too. And what will the power and torque gain be with a cams swap 20hp? School me please
Gtif is offline   Reply With Quote
Old 01-02-2012, 11:21 PM   #2
Will a set of cams give me 50 hp and boost my ftq. Or will the just change the power curve?
Old 01-03-2012, 06:04 AM   #3
t0t4lbl4ck0ut's Avatar
Well if you don't want to fiddle with clearances then you'd better stay with a stage 1 can which will add a bit more power but more likely just stretch out your powerband a bit. You may get away with a stage 2 cam without problems but your taking a chance. I had no problems but mine were custom grinds. Also with stage 2 you'll most likely have to change your springs. Which isn't much more work really.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 01-03-2012, 06:16 AM   #4
Ty I'll stick with stage 1 until I forge the bottom end in the summer.
Old 01-03-2012, 07:33 AM   #5
Re: Cams for the 02 gt
if your going to change cams this summer when you forged the bottom end why not just want to do a cam this summer so you can get a better profile than a stage 1?
but go with a comp 262 or check out modularheadshop.com.. his stage 1 cams can be ran with stock valve springs...but i personally recommend doing better valve springs and all cams just for piece of mine and better seat pressure
slow02gt is offline   Reply With Quote
Old 01-03-2012, 11:26 AM   #6
504gt's Avatar
My stage 2 comp cams, don't have any clearance issues, but you def need new valve springs with anything stage 2 and above, prolly would be best to just get new ones with a stage 1 aswell
504gt is offline   Reply With Quote
Old 01-03-2012, 04:54 PM   #7
Mzilla's Avatar
I have the comp cams xe274h xtreme energy with beehive valve springs and titanium keepers. I had no clearance issues running 14 lbs of boost
Mzilla is offline   Reply With Quote
Valve covers!!! Coreyw428 1996-2004 Mustang GT 22 12-12-2011 11:53 AM
STage 3 cams 4 sale. wnt2gofst 2011-2014 Mustang GT 2 10-18-2011 03:19 PM
Will Stock 1998 GT H-Pipe Fit My 2003 GT? Brent 1996-2004 Mustang GT 5 10-12-2011 09:44 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 05:49 AM
08:44 PM
