Blew a spark plug... - Mustang Evolution
Old 12-31-2011, 06:58 PM   #1
Cajunick's Avatar
Well it seems I blew a spark plug out of my cylinder head by just starting my car. I removed the coil and inspected it and the threads are gone. Is there a helicoil kit I can get at a local parts store? Or has this happened to anyone else what are some options here I can do?
Cajunick is offline   Reply With Quote
Old 12-31-2011, 07:15 PM   #2
DaBluedude's Avatar
There are helicoil kits available. Usually tho, this is going to require some $$$ and often requires pulling the head. Good luck.
2003 Mach 1
Old 12-31-2011, 07:15 PM   #3
deadsp0t's Avatar
Heli-coil in a head is not easy to do. I would do some looking around as to which Heli coil you should use, like brands.
My 900 needs a Heli coil in the head too, I'll be taking mine to a shop to get done. That way if it's wrong I can be mad as them not me..
That's unimpressive
Old 12-31-2011, 07:17 PM   #4
deadsp0t's Avatar
Honda said they could do the one on my w/o pulling the engine, would think the same in a car with relation to the head. I don't know though.
That's unimpressive
Old 12-31-2011, 08:06 PM   #5
DaBluedude's Avatar
Sorry I used bad grammar. I meant to say there are helicoil kits and that can be done without removing the head (tho I wouldn't want the metal shavings in the head!!!). The proper way is to remove the head and properly fix it.
Or you could do the top gear fix and epoxy it in place. Lol
2003 Mach 1
Old 12-31-2011, 08:11 PM   #6
deadsp0t's Avatar
Several ppl told me on the bike, to pack the right tap w/ grease. Do less then a 1/4 turn, back it out, clean repeat! Think I'll let a shop do it lol
That's unimpressive
Old 12-31-2011, 08:20 PM   #7
504 Stang Rida's Avatar
I had the same problem with mines and it turned out my engine wireharness had a short in it...so if you can find a used one you should test it out before you do anything
504 Stang Rida is offline   Reply With Quote
Old 12-31-2011, 08:49 PM   #8
Cajunick's Avatar
Re: Blew a spark plug...
Well I figured I could get it done without pulling the head. Its in a easy spot for me to tap it. I was just wondering if anyone had used any specific helicoil kit.
Old 01-01-2012, 12:36 PM   #9
Frankensteins's Avatar
I've done it to my personal car and also to a couple of my customers car...if your doing it for the first time I HIGHLY recommend having enough money to get all new gaskets and sending the head to get decked...because the first time I tapped it with a kit from advance(I'll get you the part number later) everything went fine, but when I screwed in the tap sleeve I screwed it in just a little too far. So the piston was hitting it.
Frankensteins is offline   Reply With Quote
Old 01-01-2012, 03:33 PM   #10
Cajunick's Avatar
Well it looks like I can buy a Time-Sert kit like this... Amazon.com: M14 X 1.25 Time-Sert Extended Spark Plug Thread Repair Kit: Automotive It's 181 dollars I dont have... Way to start off the new year blown a spark plug out of my head and to top it all off its my birthday lol. Seems that I can't ever catch and break and yet another crappy year it will be for me... -end rant
Old 01-01-2012, 03:37 PM   #11
$181!!!! Dang!! That is wayyyy too much...the kit that advance auto parts has is $37! It comes with 3 different inserts so you can use the factory size spark plug. USE THE SHORTEST INSERT!!!! Trust
Me
Old 01-01-2012, 06:46 PM   #12
Cajunick's Avatar
Me
Why the shortest insert?
Old 01-01-2012, 07:09 PM   #13
To match the depth of the spark plug tread length in the head
Old 01-02-2012, 03:49 PM   #14
Cajunick's Avatar
Buy Fix-A-Thred M14-1.25 Plug-Saver Kit - 1 each insert S, N, L 98141 at Advance Auto Parts
Is that what you used?
Old 01-03-2012, 08:39 PM   #15
For some reason I can't open up the link on my phone...I'll have to get on the computer and look at it, but the definition sounds right.
Old 01-03-2012, 09:32 PM   #16
Cajunick's Avatar
Well I had that set setting in my tool box from years ago when I worked at a dealership I installed a insert in a customers vehicle. I just didn't have the inserts and totally forgot how I did it because it was around 5 years ago lol. Anyway I figured it out and just went buy the small black solid insert and installed it tonight. Th spark plug is nice and tight I'm just letting the lock tight set until the morning. I'll say a little pray and start it then lol. ::cross fingers::
Old 01-04-2012, 09:16 AM   #17
Cajunick's Avatar
Ok the beast is back on the road. I fixed it with that kit incase anyone was wondering/cared lol.
Old 01-04-2012, 10:36 AM   #18
Brett Greene's Avatar
Was literally just gunna say this. I have done this 3 times on my 1995 now. No problems. Just take your time
Brett the best Greene
Brett Greene is offline   Reply With Quote
Spark Plug wire Clips RollinonGT 1996-2004 Mustang GT 1 12-12-2011 01:07 PM
Major Engine Trouble With Spark Plug Coils 504 Stang Rida 1996-2004 Mustang GT 4 09-29-2011 02:38 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
How Do I Clean Out My Holes? ...spark plug holes? Nel86 General Car Discussion 8 08-06-2011 03:55 PM
Spark plug blown out of head. 1bad2v 1996-2004 Mustang GT 17 07-03-2011 08:29 PM
12:56 PM
