throttle body? - Mustang Evolution
Old 01-02-2012, 12:33 PM   #1
pondit0's Avatar
I was told a a bigger throttle body would give me a little more power. Is this true or just a waste of money? If so what's the best bang for my buck and what size is best? I already have a cold air intake.
pondit0 is offline   Reply With Quote
Old 01-02-2012, 12:40 PM   #2
Gears
Gtif is offline   Reply With Quote
Old 01-02-2012, 12:56 PM   #3
pondit0's Avatar
I do plan to do the gears later but is the throttle body worth it?
Old 01-02-2012, 01:50 PM   #4
Mile high JDF's Avatar
If you do the plenum/throttle body combo it should get you some power. If you get a tuner that should help maximize the power gains.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-02-2012, 02:47 PM   #5
Eturner's Avatar
+1 A plenum/throttle body combo will net you some hp but not much!.. That is until you Supercharge or turbo it (if you plan on going that route)!.. BBK makes a one piece 78mm TB/plenum!.. Other than that the largest there is is a 75mm TB!.. I went with a 75mm TB/plenum combo and I got a little extra hp!.. But I'm also planning a SC some day soon!..
---------- Post added at 04:47 PM ---------- Previous post was at 04:46 PM ----------
Also if you haven't already get a tuner!.. SCT and DiabloSport are both pretty good!..
Old 01-02-2012, 03:42 PM   #6
I agree. And quote me if I am wrong. We usually start with throttle body and plenum cold air intake and then the tuner
Old 01-02-2012, 03:48 PM   #7
Eturner's Avatar
Personally I think those three things should go hand n hand!.. Because I don't think you are really going to realize the potential of any of those parts with out the other two!..
Old 01-02-2012, 04:24 PM   #8
pondit0's Avatar
Thanks a lot guys.
Old 01-02-2012, 05:10 PM   #9
Eturner's Avatar
Originally Posted by pondit0
Thanks a lot guys.
No problemo!!... Lol
Old 01-02-2012, 10:07 PM   #10
I agree
Old 01-02-2012, 10:09 PM   #11
Berbantor's Avatar
Don't go any bigger then 75 mm unless ur r plaining to sc it later its a waste.
2001 gt, 5speed. 70mm throttle body with stackracing plenum. bbk intake, 4.10 eaton posi, short shifter, o/r side exhuast.
Berbantor is offline   Reply With Quote
Old 01-02-2012, 10:17 PM   #12
Eturner's Avatar
+11
Old 01-03-2012, 11:54 AM   #13
AgentOrange's Avatar
Not trying to hijack, but I am running AM's CAI with a K&N cone fashioned up to it, catless H pipe and flowmasters.. Next to bat was going to be a Trick Flow 70mm TB/plenum and an SCT.. Am I wasting money on the TB? I don't want to spend a few hundred dollars to get nothing. I was expecting at least 8HP.
AgentOrange is offline   Reply With Quote
Old 01-03-2012, 12:11 PM   #14
Berbantor's Avatar
No unless ur going to sc it. That Would be perfect. I'm running a 75 mm stack racing with plenum. Notice some difference and a lot better throttle response. But the 70mm will do.
---------- Post added at 01:11 PM ---------- Previous post was at 01:10 PM ----------
Well that's on my 01 gt.
Old 01-03-2012, 12:12 PM   #15
Re: throttle body?
Just did a 75 mm BBK with a 78mm trick flow plenum I found on craigslist for 70 bucks still in the box. It gave im guessing 10 hp at the wheels and feels alot smoother pulling to redline.
blk04gt is offline   Reply With Quote
Old 01-03-2012, 12:23 PM   #16
Well ill go 75, but I figured N/A I'd get more velocity out of the 70. If I pick up around 10hp I'll be happy.
Old 01-03-2012, 12:28 PM   #17
Berbantor's Avatar
That's the way to do it LOL
Old 01-03-2012, 05:06 PM   #18
Well, yeah. The real question was if it will net me a gain.
Old 01-03-2012, 05:16 PM   #19
Eturner's Avatar
Originally Posted by AgentOrange
Well, yeah. The realy question was if it will net me a gain.
It will but don't expect large gains!..
Old 01-03-2012, 05:38 PM   #20
Torrbo916's Avatar
I have a professional products tb and plenum. They are pretty nice. I made sure to clean up the inside casting of the plenum. It was pretty rough. It definitely help the throttle response. And it gave it a cool sound when the air rushes in.
Torrbo916 is offline   Reply With Quote
Old 01-11-2012, 03:01 PM   #21
I recently am having to replace my intake manifold. so, in shopping for the best prices i decided to go with the cheaper upgraded performance improvment model from am. I also thought if I was going to take the IM off I should go ahead and upgrade the TB and plenum as well. My question is I only have enough $$ to buy either the cheaper cold air inake or the stack racing intake spacer. I originally was going to buy the SRIS because everything was going to be off already but, then a friend of mine was saying some ppl say the SRIS doesn't really do much and i should go with the cold air inake. Any thoughts???
Kingjax03GT is offline   Reply With Quote
Old 01-11-2012, 03:06 PM   #22
Torrbo916's Avatar
Google reviews on it.
Old 01-14-2012, 08:55 AM   #23
Google, huh. Thats it. Thnx
Old 01-14-2012, 10:07 AM   #24
Torrbo916's Avatar
Sorry. I don't know any thing about the spacer. Nor have i read anything about it. I do know that a cheap intake with a good filter will be just fine. I would do the intake.
Old 01-14-2012, 12:07 PM   #25
MMVEC's Avatar
Typically you will see about 4-5 hp from just the spacer alone.
MMVEC is offline   Reply With Quote
Old 01-14-2012, 12:26 PM   #26
It's not me, it's you.
primer2tone's Avatar
If you're stock. A spacer isn't gonna do anything for you. You'd be better off saving what you've got and put it towards a tuner or exhaust. Hp gains from a TB spacer would be more noticeable if you had other mods to accommodate it.
I'm only saying this because I've done some reading and in most cases a mod that will only gain a few hp over stock will be unnoticed at the dyno because you will almost never make the same numbers twice.
I'd save for a tuner, then an cai, then a full exhaust.
Old 01-14-2012, 12:41 PM   #27
Eturner's Avatar
I got a TB spacer from Steeda a couple years ago for my GT!.. They claim 2-4hp NA and 4-8hp with FI!... At the time it was only like $25 and I figured why not!.. I haven't seen any solid gains from it but nothing negative from it either!..
Old 01-14-2012, 02:29 PM   #28
MMVEC's Avatar
That's my point. For the money, it's worth adding it, especially if you're adding mods later.
Old 01-14-2012, 02:36 PM   #29
pondit0's Avatar
If I were to get a new throttle body, would a spacer come with it? Everything I am reading about the TB and TB spacers is that either one only gains up to about 5 to 10 HP. The price difference is huge. Does anyone have either one or both? What is the real deal for the money?
Old 01-14-2012, 03:26 PM   #30
Eturner's Avatar
I have a 75mm TB and matching upper plenum (elbow)!.. I also have the "TB" spacer from Steeda (it actually mounts between the upper plenum and intake manifold)!.. At the time I got it, it was about $25!.. They said it would gain about 2-4hp on a NA motor and 4-8hp on a FI motor!..
Any TB and TB Spacer on a NA motor will net you a gain but it will be minimal!.. Those things usually don't start to shine until you start upgrading your heads, cams, and/or go FI!... Between the TB, upper plenum, and spacer I probably gained about 12hp!...
Old 01-14-2012, 04:01 PM   #31
pondit0's Avatar
Thanks man.
Old 01-14-2012, 04:47 PM   #32
Eturner's Avatar
No problem!..
Old 01-14-2012, 07:04 PM   #33
Thnx, gents
Old 01-14-2012, 07:18 PM   #34
MMVEC's Avatar
Thnx, gents
No problem!
Throttle Body? 2011CS 2011-2014 Mustang GT 2 11-14-2011 06:28 AM
Throttle body? Aggiesrok 2005-2010 Mustang GT 6 08-29-2011 07:04 PM
Throttle Body Whistles GTtopgear General Mustang Discussion 8 08-13-2011 09:24 AM
Throttle body help. austinray4142 Pre-2005 V6 Mustang 4 07-26-2011 03:29 PM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
03:55 PM
