NEED HELP! 1998 Corolla! - Mustang Evolution
Old 01-03-2012, 01:57 PM   #1
FORDGT14's Avatar
I need some help with a 98 Corolla LE. It will not start and Ive ran a hot wire to the fuel pump and it sprays fuel on the engine when i disconect the fuel line. But it wont start? Any relays or any good tips would be cool!
Thanks guys
FORDGT14 is offline   Reply With Quote
Old 01-03-2012, 02:20 PM   #2
Re: NEED HELP! 1998 Corolla!
Here is the simple way to diagnose a no start. Spray starting fluid in the intake thru a vacuum line while having someone crank the motor>
If it runs you have a fuel problem. If not its spark related> to diagnose ignition problems try this. Pull a spark plug and plug the wire back on. lay it down with the threaded part of the plug on metal(which grounds it allowing it to spark). Crank and look for spark No spark it could be several things, ie bad coil, bad wires, bad crank sensor. You should also check to see if it has jumped time, or water in fuel, and just give it a once over looking for broken wires bad grounds etc. The above ignition stuff will only work on cars with plug wires I wouldnt try that with a coil on plug setup.
blk04gt is offline   Reply With Quote
1998 Mustang Cobra 98RedGT 1996-2004 Mustang GT 20 09-29-2011 09:44 PM
1998 GT production figures Big Den General Mustang Discussion 2 09-11-2011 05:08 PM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 12:29 AM
08:19 PM
