98 mark 8 shortblock. - Mustang Evolution
Old 01-04-2012, 10:22 PM   #1
Torrbo916's Avatar
So I came acrossed a deal on a bottom end from a 98 mark8 with 70k on it($100). It's aluminum. Is this worth the time and effort to tear down and re assemble for my gt. What are the pros and cons. Any common issues with the aluminum block. Would I be able to use termi heads and an 03 timing set on this. Is everything pretty solid on these as well. please help.
Torrbo916 is offline   Reply With Quote
Old 01-05-2012, 06:15 AM   #2
Torrbo916's Avatar
Bump. Please inquire!
Old 01-05-2012, 06:48 AM   #3
Brett Greene's Avatar
Personally. All depends on what you want out of your car. As for buying it and just swapping it out with yours I wouldn't do it. But you could buy it, bore it out and build it for a bad *** motor over time. Those
Blocks are tough as nails. As for Termi parts I have no idea if they would work
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 01-05-2012, 07:30 AM   #4
onesickstang01's Avatar
Any 4.6/5.4 will accept any 2v/3v4v head. Im pretty sure that i read somewhere the people use the mark blocks and 2v heads and end up with a nice high compression motor though. Im a boost guy so i didnt get too much into it but you might want to read up
onesickstang01 is offline   Reply With Quote
Old 01-05-2012, 07:37 AM   #5
Torrbo916's Avatar
What about internals. I've had some people say forged crank and some say cast crank. Both said it has the same rods and pistons as a gt. Any thoughts. I know the termi internals ar all forged. At least the crank should be in the mark 8 right??
Old 01-05-2012, 09:19 AM   #6
AgentOrange's Avatar
Pretty sure its cast cranks in the Marks. Forged connecting rods and pistons? I'll need backup on this one though.
AgentOrange is offline   Reply With Quote
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Mark 8 shortblock. Torrbo916 SVT Mustang 10 01-18-2012 12:12 AM
08:43 AM
