Trick flow top end kit 1996 4.6 - Mustang Evolution
Old 01-05-2012, 08:23 AM   #1
Rebbew's Avatar
I'm going to do the trick flow top end kit but I don't think the bottom end will hold. It's all stock and I don't know what size pistons rods or crank to get. Don't know what hp the stock crank can hold. I've been looking but don't know what to buy. Don't want to get the wrong thing and the top end kit not work. Any help will be greatly appreciated. Thanks
Rebbew is offline   Reply With Quote
Old 01-05-2012, 05:08 PM   #2
t0t4lbl4ck0ut's Avatar
As long as you stay naturally aspirated you should be fine. I don't think the 4.6 can get enough power naturally to ruin the motor.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 01-05-2012, 06:35 PM   #3
98prosnake5.4's Avatar
Yeah you should be good on the motor but the teams I going to be the week link just beef it up a lil and you should be good
98prosnake5.4 is offline   Reply With Quote
Old 01-06-2012, 10:20 AM   #4
CodyNelson's Avatar
Region: West Virgina
Re: Trick flow top end kit 1996 4.6
the trans will be fine. depending on how you drive you may want to look into a clutch though lol
Old 01-06-2012, 03:11 PM   #5
It's not just about power, you have to be careful with revs on a stock bottom end. The specialist that I know works closely with Sean Hyland and is adamant you should not rev over 6,000 rpm as it will eventually lead to bottom end failure. I quite fancy the trick flow but with peak power looking to be in the 5,800 to 6,200 rpm range with the PI intake you will really need to upgrade the bottom end.
Ksilver is offline   Reply With Quote
Old 01-08-2012, 09:31 AM   #6
Rebbew's Avatar
I was reading on a thread a guy had a pi swap kit installed by ford and his piston shattered. Not sure if it was how he was driving it or not I just want to have that problem. And I've owned a 2003 mustang gt so I drive right. Get on it when needed. Thanks for the help.
Storker kit fits top en kit 281 Rebbew 1996-2004 Mustang GT 0 12-14-2011 03:31 PM
Trick flow opinions Tj88mustang 1979-1995 Mustang GT 11 12-04-2011 02:46 PM
Trick flow top end Jesse Bach General Mustang Discussion 0 12-03-2011 07:04 AM
Trick flow top end kit Jesse Bach General Mustang Discussion 4 10-12-2011 07:45 AM
Trick Flow 1.6 rocker arms for sale!! WhiteCobra94 Mustang Parts for Sale and Wanted 1 08-09-2011 09:05 AM
11:38 AM
