squeak - Mustang Evolution
Old 01-07-2012, 10:27 AM   #1
edgar_32's Avatar
squeak
My car has a squeaky noise on the right hand front tire it makes noise like on bump or something and when i turn wat could that be?
edgar_32 is offline   Reply With Quote
Old 01-07-2012, 10:39 AM   #2
onesickstang01's Avatar
Sway bar endlinks, sway bar bushings, ball joints, a arm bushings, strut, strut bushing, lol could be alot
onesickstang01 is offline   Reply With Quote
Old 01-07-2012, 10:40 AM   #3
96stangracer's Avatar
Check your ball joints alot of times it is the lowers you check this by raising the car and prying down with a pry bar in between ball jont and control arm and take a look at the bushings they maybe rotted or cracked
96stangracer is offline   Reply With Quote
Old 01-07-2012, 11:07 AM   #4
Common issue with New Edge body. All three of my 04's made that damn noise. I bout poly rack bushings and fixed the issue. Just a thought
SNK3BTE04 is offline   Reply With Quote
Old 01-07-2012, 11:39 AM   #5
02PONY's Avatar
Just spray a little wd on each bushing 1 at a time drive around the block when sqeak stops u found your problem
02PONY is offline   Reply With Quote
Old 01-07-2012, 03:32 PM   #6
edgar_32's Avatar
Thanks ill check that out kus its getting to me already.
I sprayed wd on aloot of things down there kus i couldnt figure out where exactly was that noise coming from so i did that but i guess it didnt work lol but ill do that thanks for your help
Window lowers and makes a squeak GTtopgear 1996-2004 Mustang GT 3 11-13-2011 10:38 AM
09:49 AM
