Dont drive on a flat tire.. - Mustang Evolution
Old 01-07-2012, 07:21 PM   #1
JetLife 01GT's Avatar
It didnt even make it 5 blocks to the gas station!!! Sob..
---------- Post added at 06:21 PM ---------- Previous post was at 06:19 PM ----------
I'm on 3G so it won't let me load a pic but the tire is shredded. I will post pic later
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-07-2012, 07:28 PM   #2
deadsp0t's Avatar
Just hope the wheel isn't trashed. That sucks.
That's unimpressive
Old 01-07-2012, 07:37 PM   #3
The wheel is good, thank god. $125 for a new tire.
2001 GT
Old 01-08-2012, 01:21 AM   #4
2001 GT
Old 01-08-2012, 01:25 AM   #5
deadsp0t's Avatar
Your very lucky man!!!!
That's unimpressive
Old 01-08-2012, 03:40 AM   #6
blackhawk 1's Avatar
Re: Dont drive on a flat tire..
wow , shredded !
blackhawk 1 is offline   Reply With Quote
Old 01-08-2012, 12:41 PM   #7
Yes I am
Originally Posted by blackhawk 1
wow , shredded !
I was shocked it did that much damage to the tire..
2001 GT
Old 01-08-2012, 01:00 PM   #8
I see this every day word for the wise for the rest of u even driving with low air can damage ur tire example if ur tire says max pressure 44psi dont run it less ten 15psi for any extended period it will wair the rubber off of the inside of the tire were the side wall joins to the crown of the tire weakining the casing and causing the potencial of a blow out and to all u that say bs i run less than that at the track u need spiecial tub style tires or spiecially manufactured tire to do that on a regular bases do to often and ill be seeing u soon at my tire shop for new rubber if u dont wreck when u blow out.... Optamial performance fuel econamy and ride comfort are achieved on a tire with a max pressure of 44psi when run at approx 35psi... Tire shope rule of thumb: 10 psi less then max on all 4-6ply tires (44-60psi rating) belive me i know tires its what i do for a living.
Hawk is offline   Reply With Quote
Old 01-08-2012, 04:00 PM   #9
Loc: Austin,TX
Why in the hell would you try and drive blocks on a flat?
Old 01-08-2012, 07:49 PM   #10
It wasn't totally flat and I didn't have much of a choice. I'm currently without a compressor
2001 GT
Old 01-08-2012, 08:11 PM   #11
vinnygt's Avatar
125 isn't too bad I guess..I had to pay 500 for 2 used tires for my Saleen rims
vinnygt is offline   Reply With Quote
Old 01-08-2012, 08:52 PM   #12
Did you mess-up you fender?
Gtif is offline   Reply With Quote
Old 01-08-2012, 11:45 PM   #13
I was pretty happy with $125. Got $50 off, my uncle works at a tire place. No damage except to the tire and a few dings in my bank account lol
2001 GT
To drive or not to drive 2011 Kona Blue 2011-2014 V6 Mustang 41 01-26-2012 08:53 PM
2004 GT 315 Tire Rubbing Issue TheJigShow 1996-2004 Mustang GT 11 11-13-2011 07:31 AM
Alabama Baugh Ford Drive Clanton, AL Cruise In Oct 8 SpectorV Regional Mustang Discussion 1 10-04-2011 12:25 PM
What tire should I go with? poloka General Mustang Discussion 7 09-08-2011 09:19 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
09:08 PM
