Cold air intake - Mustang Evolution
Old 01-08-2012, 05:06 PM   #1
Cold air intake
What's the best cold air intake out there ? That provides the best flow and all that.
96gt014.6 is offline   Reply With Quote
Old 01-08-2012, 05:09 PM   #2
03GT88's Avatar
I think there all pretty much the same performance wise. the ones with the air filter in the fender is the way to go.
03GT88 is offline   Reply With Quote
Old 01-08-2012, 05:12 PM   #3
Alright, right now I just have a factory air intake. So I kind of want to upgrade. But thank you
Old 01-08-2012, 05:18 PM   #4
BigB227's Avatar
Just go with the one that AM sells there all pretty much the same lol I got the one from Stage 3 Motorsports and it works great. It's defiantly an improvement from stock
BigB227 is offline   Reply With Quote
Old 01-08-2012, 05:21 PM   #5
DaBluedude's Avatar
Yeah the cai kits are good. I recomend JLT personally. Biggest pipes in the business, but prob wont clear a strut bar.
2003 Mach 1
Old 01-08-2012, 05:50 PM   #6
I think anything is probably better than stock, but thank you.
Old 01-08-2012, 09:48 PM   #7
MustangGT02's Avatar
Re: Cold air intake
I went with the AM, it looks just like the BBK lol and works just fine. You can really tell it is sucken better than stock, my whole car sounded better after I installed it.
MustangGT02 is offline   Reply With Quote
Old 01-08-2012, 09:55 PM   #8
I'm going to have to look into those once I get the money, first is a paint job once I get the engine back.
Old 01-10-2012, 07:23 PM   #9
lConnerl's Avatar
Region: Oregon
I'm looking into installing the Mach 1 shaker hood and ram air kit. I found a bolt on upper plenum and TB that is a Mach 1/Cobra style TB then from there I just get the shaker hood kit a Mach 1 cai, and the Mach 1 hood and I'm set. Well bigger injectors as well but I planned on that already.
lConnerl is offline   Reply With Quote
Old 01-10-2012, 07:36 PM   #10
DaBluedude's Avatar
Ur doing this on a gt? Your better off just getting the hood, brackets, and shaker. I'm not certain but I'm pretty sure ur tb/plenum is different. The shaker kit really is just a visual thing.
2003 Mach 1
Old 01-10-2012, 07:49 PM   #11
lConnerl's Avatar
Region: Oregon
I found a bolt on TB and upper plenum that bolts right to the factory PI lower intake plenum. the TB is not a twin blade but is still an oval shape. So I can run the ram air intake from the Mach 1. All I have to do is get the cai for a Mach 1 and the kit, I don't have to buy the Mach 1 hood but I don't like the idea of cutting holes in my current hood, not my idea of a good time haha.
---------- Post added at 06:49 PM ---------- Previous post was at 06:47 PM ----------
Lethal performance has the TB and upper plenum combo, late model restoration has the shaker hood kit and cai I want. It's going to be expensive in the long run, but it will look good and I would rather have a legit ram air intake instead of the fender style cai.
Old 01-10-2012, 08:36 PM   #12
DaBluedude's Avatar
The shaker isn't a ram air. It just loosly pipes air to the filter. I agree its sweet and looks great but it really isnt that functional.
You can see the pipe from the shaker just links upto the filter. Most of the air comes from the fender.
2003 Mach 1
Old 01-10-2012, 08:37 PM   #13
MiGT01's Avatar
Re: Cold air intake
Ive been told that BBk is pretty good and not that badly priced. I pretty sure theres others out there way cheaper. I have the BBK and its great but my buddy is sending me his old JLT...He says that JLT is the very best when it comes to CAI..
MiGT01 is offline   Reply With Quote
Old 01-10-2012, 08:40 PM   #14
I never really paid attention to CAI and which Is better, but sadly I won't be able to afford a aftermarket one anytime soon.
Old 01-10-2012, 08:45 PM   #15
lConnerl's Avatar
Region: Oregon
Ok so ram air isn't correct but it still feeds cold air directly to the intake instead of it being routed through the fender. That and I'm sketchy about pulling water in through the fender cai, I've seen a buddy blow is motor because of that.
Old 01-10-2012, 08:52 PM   #16
DaBluedude's Avatar
That's fine. I went with the shorter jlt rai instead of the deep fender rai, to keep the shaker functional. Its a pricey mod for sure but it looks good. Make sure you treat the shaker regularly, they fade really easily.
2003 Mach 1
Old 01-10-2012, 11:09 PM   #17
Torrbo916's Avatar
My bbk doesn't even clear the strut bar. It has a big rust spot where the strut touches the elbow. I might switch to a cobra strut bar.
Torrbo916 is offline   Reply With Quote
Old 01-11-2012, 12:46 AM   #18
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I like my MAC col air intake
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
cold air intake
Cold air intake without Tune RedToplessPony 2011-2014 V6 Mustang 14 12-28-2011 12:04 PM
Best cold air intake? Pstang5 2011-2014 V6 Mustang 11 12-27-2011 07:47 AM
Cold Air Intake itsme37421 2011-2014 Mustang GT 23 11-10-2011 02:37 PM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
09:50 AM
