4.6 ideas help! - Mustang Evolution
Old 01-08-2012, 09:26 PM   #1
4.6 ideas help!
So I just recently bought a 97 mustang 4.6 v8 5 speed with 117k miles on it for a steal so I want to use it as a donor car for a swap into another car, my ideal car to swap it into is a datsun 510 but idk if it's too big? Help on ideas of a car that would fit the sohc 4.6 in it would be greatly appreciated... And what do I need for the swap? The car is complete and running so is it as easy as just swapping the tranny engine and electrics? Or do you have to swap rear end and suspension too? Help?!
Hunter45 is offline   Reply With Quote
Old 01-08-2012, 09:32 PM   #2
Eturner's Avatar
4.6 to big?!?.... No!.. 4.6 is actually a small block in the engine world!.. A 4.6 is actually a 289 cu inch and I've seen a older Datson that had a 350 under the hood!.. As far as what is needed to do a swap like that I wouldn't know!..
Old 01-08-2012, 10:01 PM   #3
A 4.6 is a 281
96gt014.6 is offline   Reply With Quote
Old 01-08-2012, 10:24 PM   #4
Mustang_Madness's Avatar
Re: 4.6 ideas help!
289. I have it and guarantee its a 289.
Mustang_Madness is offline   Reply With Quote
Old 01-08-2012, 10:33 PM   #5
Mile high JDF's Avatar
The block is small but the heads are what make it look big
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-08-2012, 10:53 PM   #6
Eturner's Avatar
True!..
Old 01-09-2012, 01:01 AM   #7
JetLife 01GT's Avatar
The sn are 281. The old ford motor was 289
---------- Post added at 12:01 AM ---------- Previous post was at 12:01 AM ----------
I have both
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-09-2012, 07:24 AM   #8
Snapple750's Avatar
Definitely 281
Bore: 3.552 inches (90mm)
Stroke: 3.543 inches (90.2mm)
You do the math
289 is a 4.7 liter
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 01-09-2012, 07:57 AM   #9
Eturner's Avatar
Originally Posted by Snapple750
Definitely 281
You do the math
289 is a 4.7 liter
I stand corrected!!.... Hahaha.
But I'm sure it is plenty small enough to fit inside his Datson!.. Would be interesting to see too!..
Old 01-09-2012, 08:04 AM   #10
You got me to. Would a 5.0 be a 302 or what??
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Old 01-09-2012, 10:21 AM   #11
Yup
2001 GT
Old 01-09-2012, 07:18 PM   #12
Snapple750's Avatar
I agree, a 302 might fit a little better because it is an ohv. But I'm pretty sure the 4.6 will fit.
2 Legit 2 Quit
Old 01-10-2012, 07:26 AM   #13
onesickstang01's Avatar
Also the 302 isnt a true 5 liters. 5 liters is 305 ci. That puts the 302 at about a 4.95. Basically the math to this is multiply the liters by roughly 61. As a long block the 4.6 is much larger than the 5.0 because out the heads
onesickstang01 is offline   Reply With Quote
Old 01-10-2012, 03:57 PM   #14
AgentOrange's Avatar
240sx? People do the LS1's a lot.
AgentOrange is offline   Reply With Quote
Old 01-10-2012, 08:08 PM   #15
lConnerl's Avatar
Region: Oregon
The LS1 is pretty short from pan to intake and is very low profile. The 4.6 has a lot of height to it as said before because of the heads. You would need to modify or replace the k-member (engine cradle) so you can bolt the motor mounts down and make sure there is plenty of clearance around the motor of course, you would need the power train and computers, wiring harness, you would probably have to modify/replace the fuel lines to fit the 4.6 fuel rail. If height of the motor is an issue, you could always look into a cowl hood for the needed clearance. You can do anything you want if you have the time and money.
lConnerl is offline   Reply With Quote
4.6 vs police 4.6 deadhorse 1996-2004 Mustang GT 26 11-22-2011 09:23 PM
4.6 bottom end rebuild. Ideas please SonicBlueGT9963 1996-2004 Mustang GT 10 10-31-2011 07:12 AM
custom plate ideas king 5.0 2011-2014 Mustang GT 22 10-18-2011 04:11 AM
10:48 AM
