Clicking sound?! - Mustang Evolution
Old 01-11-2012, 12:46 PM   #1
ColeJohnson's Avatar
Clicking sound?!
Just lowered my '02 GT. Steeda X2 balljoints, Steeda Bumpsteer kit, H&R SS springs with polyurethane bushings. Also installed maxim motorsports camber/caster plates.
Whenever driving I hear a loud clicking sound from the driver front, and a very faint clicking sound from the passanger front(maybe just an echo from driver side). I put it back on jacks and checked everything and all bolts are tight and everything is good. When I have the car on the ground I can push down on the driver side fender and it produces the loud clicking sound. Pushing on the other corners yields no noise except on the passanger fender in which case the clicking noise happens from the driver side.
I have yet to get an alignment and get the camber/caster set by a pro, and I'm waiting on my new Shocks/struts to get here, but had installed everything already.
Could it possibly be that the camber is out of whack and just making things make noise? Or could it be that my stock struts are not up to the task? Only thing that is confusing me is that it happens sometimes while rolling, but each time when you bounce it.
Any ideas, please? I need to get this solved today.
2016 Comp Orange GT (current)
Old 01-11-2012, 01:32 PM   #2
TheNewKid's Avatar
Re: Clicking sound?!
mine clicks to some degree when lowered, no errors at all that i could find. not throwin any codes, everything is on right... im dropped 2in aswell
CAI, Off-road H-Pipes, 3.73's and a short throw. UDP and Tuner should be here any day....
TheNewKid is offline   Reply With Quote
Old 01-11-2012, 01:34 PM   #3
Cobrarunnin9s's Avatar
By chance it's not your driver side frame sway bar mount is it? Or possibly the strut bushing is wasted.
Cobrarunnin9s is offline   Reply With Quote
Old 01-11-2012, 02:09 PM   #4
Strut bushing? It's a brand new maxim motorsports one that came with the camber caster plates.
I notice it does it a lot when it bounces up an down but just sometimes clicks during driving and cutting the wheels left or right..
---------- Post added at 02:09 PM ---------- Previous post was at 02:09 PM ----------
Are the lower control arms supposed to be angled up away from the ground?
Old 01-11-2012, 02:37 PM   #5
irishn8's Avatar
I recomend having someone push down on the car while you locate the sound.
Old 01-11-2012, 03:16 PM   #6
onesickstang01's Avatar
Control arms will angle up as you lower it. Make sure the ball joint is seated correctly. Pressing new balljoints in sometimes have issues with not seating correctly and make that noise
onesickstang01 is offline   Reply With Quote
Old 01-11-2012, 03:18 PM   #7
Are the lower control arms supposed to be angled up away from the ground?[/QUOTE] ya they should be close to parallel with those steeds ball joints I would think.
Old 01-11-2012, 08:30 PM   #8
Put it up on a rack and we found out the loud clicking is coming from the ball joints. They are brand new steeda x2s... What the hell? I hope American muscle works with me on this..
Old 01-11-2012, 08:37 PM   #9
SSC182's Avatar
If I were you I would try and find a set of moog ball joints that fits in my opinion those are the best money can buy
SSC182 is offline   Reply With Quote
Old 01-11-2012, 08:50 PM   #10
Even with lowered suspension?
Old 01-11-2012, 09:56 PM   #11
dumb question, but did you grease the ball joints? because that will make them click.
Old 01-11-2012, 09:58 PM   #12
I thought the x2s came pre-greased. Never heard on anyone putting more in it.
Old 01-11-2012, 10:09 PM   #13
try adding grease to them and see what happens, I just downloaded the instructions and they say:
5. Install the grease fitting in the bottom of the new balljoints
and lubricate with good quality high-pressure grease.
Old 01-12-2012, 02:49 AM   #14
I Put it back on stands and went trough every nut and bolt again, checked all te bushings, and even replaced the inner tie rods. Then pumped the balljoints to the brim with grease. Put it all back together and sat it down.
Tried bouncing it and moving it around and all the clicking, squeaking, and rattling is gone so far!!!
Gonna stay up all night because I'm so excited and take it to the tire shop at 8am to get my new tires and get them mounted, balanced, aligned. And setting camber caster.
Only 5 hours left! I hope it works out. Pics to come soon of the final product.
Oh.. And new shocks and struts coming soon!
ID:	37910   Click image for larger version
Old 01-12-2012, 07:47 AM   #15
Cool keep us posted on how the rest of it goes!
Old 01-12-2012, 12:01 PM   #16
94 Mustang GT's Avatar
Check your ball joints! Mine was making same kind of noise and it was my ball joint.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 01-12-2012, 12:51 PM   #17
Got the new tires and alignment and everything!! It rides great and handles tight. Noise is gone but the passenger rotor is uneven a bit. Can you turn drilled and slotted rotors?
Pics soon.
Old 01-12-2012, 01:00 PM   #18
Better pics to come soon. Everything still has to settle. I'm excited though!
ID:	37935   Click image for larger version
Old 01-12-2012, 01:32 PM   #19
Cant turn rotors that are drilled and slotted
Old 01-12-2012, 02:17 PM   #20
Ah.. So have to get brand new rotors then? Awesome.
Old 01-12-2012, 05:14 PM   #21
Also, there is a scraping metal sound coming from the passenger side. I took the brake dust shield off the driver side as called for in the ball joint installation instructions. I didn't take off the passenger side... Could it be making contact with something rotating with the wheel? I'm about to take the wheel off and try to remove it. It's just a pain to drill out the rivets. :/
Old 01-12-2012, 05:18 PM   #22
Ya you might have to take that side off as well. Good luck.
Old 01-12-2012, 05:31 PM   #23
Ah. Guess I have my next little project. Lol
Shaker Sound System(s) Y2E0L0L5OGWT Mustang Audio & Video 1 01-08-2012 10:50 PM
how could i make my 2000 v6 mustang sound louder!?? betocruzazul Pre-2005 V6 Mustang 29 01-02-2012 02:41 PM
Sound when shifting at high sppeds! deaser84 2011-2014 V6 Mustang 12 12-07-2011 06:14 AM
Popping sound while braking... 12GTstangCS 2011-2014 Mustang GT 4 11-29-2011 01:55 PM
Deep Sound 559Danny 1996-2004 Mustang GT 10 09-29-2011 07:09 PM
12:59 PM
