Bolt-ons = ? hp - Mustang Evolution
Old 01-14-2012, 10:40 PM   #1
FORDGT14's Avatar
Bolt-ons = ? hp
How much power can you make with full bolt-ons on a 99-04 Gt? (minus a supercharger/turbo)
Its a 99 Gt with a stock 4.6l. I just wana know how much hp I can make without having to build the engine, just bolt-ons.
Thanks.
FORDGT14 is offline   Reply With Quote
Old 01-14-2012, 10:47 PM   #2
jshetler122's Avatar
I know a cold air intake alone adds like 5-15 ish give or take a few exhaust and headers helps a lot
jshetler122 is offline   Reply With Quote
Old 01-14-2012, 10:53 PM   #3
FORDGT14's Avatar
Yeah i just have flowmasters
Old 01-14-2012, 11:32 PM   #4
jjsg09's Avatar
A full exhaust system will change the whole way that car feels. It's kinda amazing when you drive it the first time converting to that. But everything helps with the bolt ons. But I noticed the most from the full exhaust. You could do exhaust, programmer, and gear and that is where it most pays off.
Old 01-15-2012, 01:38 AM   #5
t0t4lbl4ck0ut's Avatar
You won't have to build the motor with just bolt ons. Do everything possible for your car bolt on wise and do some massive tires and 4.10 gears and you can run 12s with experience and weight reduction. That's flying for just bolt ons. And it is possible with enough practice.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 01-15-2012, 01:55 AM   #6
FORDGT14's Avatar
Well yeah i know i wont have to build the engine for bolt-ons, im just trying to figure out how far i can go with just bolt-ons.
And someone told me i could run 12's with bolt-ons before, what all do you have done?
Old 01-15-2012, 02:02 AM   #7
Well I think youll have to do just about everything to get into the 12s. Def full exhaust. I'm not sure what exactly you'll need cause I'm beyond the point of bolt ons.
Old 01-15-2012, 04:55 AM   #8
DaBluedude's Avatar
All rough estimates.
Cai ~ 10hp
Tb and plenum ~ mayb15-20
Headers ~ 15
Midpips o/r ~ 10
Catback ~ mayb another 10
Lower intake ~ 15
Pulleys ~ 7-10
Driveshaft ~ lower mass, revs a little faster.
tune it all and you might see a grand total of 65-75hp. You can't just add all the numbers up to get hp...
Set of mild cams will get you anothed 25-35tops.
Bigger injectors and tuning can net you some more top end power. (10 but over a lot of rev range.)
Some heads could get up to a 40hp gain if the supportig mods are done.
Oh and a shifter goes a long ways towards faster times. Only other big time mod is the gears. My opinion. 3.55 for a car that sees highway lots, 3.73 for a city car, 4.10 for agressive pulls and 4.54 for a quarter car.
To put the power down better get wider tires, posi if you don't have one, and upper and lower control arms. Suspension all round can help but the rear control arms are cheap and make a big difference.
Go forward. Build a monster!
2003 Mach 1
Old 01-15-2012, 08:52 AM   #9
I have a 01bullitt whit couple bolt ons and it thouse feel whit more hp than when I had it stock, I started whit a cai, then off-road xpipe, then cat back , after that billet steel flyweel and stage 1 spec clutch, accel coils, bbk mass airflow sensor ,and diablosport predator 91 tune , after all that the car feels more powerful, am still trying to figuer out if the previuse owner added gears because my shifts are more quicker like if I had 410 I can ride on first or second slow because my rpm get up quicker and have to shich it to third at 27mph 2300, also it lock up really quick like if it had a posi , my traction light and button dont seen to be working sow I dont know if I have bigger gears but you should get atlease 355 to start, and remember more power sow you will need better motormounts and trainny mount, even thoe I have subframe connectors I brocke my torque box along on top of the top control arms sow just picture all the torque you be gaining after you add couple bolt ons,
robertoortiz85 is offline   Reply With Quote
Old 01-15-2012, 01:54 PM   #10
jjsg09's Avatar
What was the differences you felt in the car when you put the new flywheel in?
Old 01-15-2012, 01:59 PM   #11
I belive is alittle ligther sow less vibration and it thosent affect it since the crankshaft is internaly balance, but theres more grip maybe thats why my torque box control arms brocke off, whit the stock iron flyweel there was alot of clutch sliping since iron gets hotter quicker and steel cools faster
Old 01-15-2012, 01:59 PM   #12
It will rev much faster and accelerate faster. That's the only perk you'll get from a fly wheel.
Old 01-15-2012, 02:04 PM   #13
I can even start from second gear whit a little reving and you can see how theres more grip even thoe I know ill mess up my pressure plate like that, I try it whit another stang same clutch but iron flyweel and it strugle and just slip
Old 01-15-2012, 02:13 PM   #14
? I can drop my car from 4k in second and do a burn out with the stock flywheel and clutch and 315 nitto 555r drag radials
Old 01-15-2012, 06:09 PM   #15
Smokedog's Avatar
Thanks.
I have full bolt ons minus a power adder, cams, and heads. I also have lt headers, catless x pipe, 3.73 gears, and aluminum ds. I had Delk Performance dyno tune it with a diablosport tuner and only got 255 RWHP. If I could do it all over again I would just get a supercharger and call it good.
Smokedog is offline   Reply With Quote
Old 01-15-2012, 06:18 PM   #16
2002VertGT's Avatar
I was trying to show a friend how to feather the clutch when He was learning to drive stick and took off from a dead stop in fifth gear in a dodge neon....not saying this is good on a clutch but I did not feel any slipping...and I too with a bone stock gt can spin a little taking off from second with the right rpms...
4.10 Gear/RPM thread
Old 01-15-2012, 06:24 PM   #17
Are you saying your cammed and all that or saying you havent done that stuff?
Old 01-15-2012, 06:36 PM   #18
Smokedog's Avatar
I have all the bolt ons excluding cams, heads or any power adders. I dont have any cams.
Old 01-15-2012, 07:59 PM   #19
Ok I was gonna say those aren't bolt ons lol how did you make 255 rwhp with all the bolt ons. That seems really low
Old 01-15-2012, 08:19 PM   #20
Smokedog's Avatar
Its definately low. Till this day I still dont think they actually "dyno" tune it. But I did call a couple of more speed shops and told them my results and ask their opinion about it. They both said thats about the right hp with those bolt ons. Thats why I said just save up for a power adder.
Old 01-15-2012, 08:22 PM   #21
upton7's Avatar
Re: Bolt-ons = ? hp
Gears are the only "bolt on" that will make your car any faster.
Old 01-15-2012, 08:32 PM   #22
Hey I was wondering if you guys know any 5x7s that will fit in the stock machine 460 box with good bass
Old 01-15-2012, 08:53 PM   #23
Eturner's Avatar
If you have all the other bolt ons I would think you should be 265-275hp with a good tune!...
Old 01-15-2012, 09:03 PM   #24
Smokedog's Avatar
Thats what I thought too. I've always wanted to get it re-tuned with another speed shop but i didnt want to spend an extra 300-400 bucks for a "possible" 10 hp. Or even worse, lose hp!
Old 01-15-2012, 09:17 PM   #25
well just decide how you goin to need your car , for daily driving or smashing on every stopligth kind of driving waisting full tank in one day, if your goin for the daily then just get regular bolt ons (exaust,x-pipe,cat-back,cai,coils,tune-programmer,pulleys,trouttle,ect)but if your goin to be racing in every stop sign then go head and add some cams,colder plugs,nitros , and maybe go whit that procharger or paxton,
All bolt ons and only one made a diff. Gtif 1996-2004 Mustang GT 25 01-02-2012 10:51 PM
3 bolt or 4 bolt camber plates Venomouz831 Pre-2005 V6 Mustang 9 12-22-2011 01:34 AM
Bolt on Exhaust Price PonyBoyV6 Pre-2005 V6 Mustang 2 12-18-2011 04:52 PM
What should be done so my 2010 Mustang GT could beat 2010 Camaro SS phobik 2011-2014 Mustang GT 73 10-27-2011 09:17 PM
Bolt size? Tj88mustang 1979-1995 Mustang GT 3 10-25-2011 06:48 PM
12:36 PM
