I had one O2 sensor, spark plugs, and a coil pack changed on yesterday. Now, I can't cranck the car from the inside. The guy who worked on it cranked it from underneath on the passenger side. I don't know what to do and I don't think he does either.
when you turn the key those all the gages and lights turn on ? and you probebly dont get a crank when you turn the key , those your car has or had an aftermarket alarm probebly the realay that was use as a starter killswicth is burn or loose cable, if you can open under the dash and check all cables and connections coming from steering colum, that should be your problem
---------- Post added at 08:40 AM ---------- Previous post was at 08:38 AM ----------
your swicth can also be the problem and if is a 5speed your neutral switch also can be bad
Thanks it was the alarm. I took the cable off of the battery and it started. Thank u so much for your help.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
