Dome light - Mustang Evolution
Old 01-17-2012, 12:27 AM   #1
Question Dome light
Does anyone know why a dome light would stay on after u shut the door. I have two 01 gts and both do it
0stang1 is offline   Reply With Quote
Old 01-17-2012, 06:23 AM   #2
Burkeys96GT's Avatar
Try turning your headlight switch that's where my reading light is located on my 96
Burkeys96GT is offline   Reply With Quote
Old 01-17-2012, 08:18 AM   #3
2002VertGT's Avatar
Some cars the dome light stays on for a period after you get in or out. When you are in and insert the key and turn the ign the light goes out...
If that's not the case and it always stays on look at the light it's self and see if there is a selector on it, I don't think our years have one but won't hurt to check.
The other thing is on the headlight switch, turn the knob to the left I believe. One way brightens the cluster the other way dims it....if you turn it all the way bright it turns the dome light on.
4.10 Gear/RPM thread
Old 01-17-2012, 08:34 AM   #4
GTtopgear's Avatar
This happened to me too. The only thing that worked for me was to remove the bulb itself so I wouldn't kill the battery
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 01-17-2012, 09:12 AM   #5
Frankensteins's Avatar
When you close the doors and hit the lock bottom on your key fab, does your horn beep once or twice? If its twice...then the car thinks that one of the doors are still open. And to fix that you have to find the "open" door and replace the bottom hinge, thats where the open close switch is.
Frankensteins is offline   Reply With Quote
Old 01-17-2012, 05:50 PM   #6
Re: Dome light
The horn beeps twice on both of them when u hit the lock button. I never would of known that. Thanks
Old 01-18-2012, 09:53 AM   #7
Re: Dome light
I had the same problem... There is a door sensor, if you take WD 40 and spray where the door closes it will clear your problem.
Hope this helps.
vevo08 is offline   Reply With Quote
ABS light + traction control doesnt work RedGT04 1996-2004 Mustang GT 16 11-12-2015 06:43 PM
HID Fog Light Kit For 99-04 Brent Mustang Parts for Sale and Wanted 1 11-20-2011 03:29 PM
Help with door locks and dome light Blazed Pre-2005 V6 Mustang 2 11-09-2011 05:33 PM
Dome light problems 98projectpony Pre-2005 V6 Mustang 2 10-20-2011 10:59 AM
Empty light Jump3back 2005-2010 V6 Mustang 13 10-06-2011 02:51 PM
09:50 PM
