How to check COPs - Mustang Evolution
Old 01-19-2012, 03:17 PM   #1
MustangGT02's Avatar
How to check COPs
I think I have a c.o.p. going bad what it the best way to single out the bad one?
MustangGT02 is offline   Reply With Quote
Old 01-19-2012, 09:57 PM   #2
03GT88's Avatar
the best method would be to have the car scanned and it will tell you what cylinder is missing. then you got to determine if its the cop or plug. to do so move the missing cylinder cop to another cylinder and re scan if the miss follows to that cylinder the cop is bad if the original cylinder is still missing that tells you that the problem is the plug.
03GT88 is offline   Reply With Quote
Old 01-19-2012, 10:24 PM   #3
94 Mustang GT's Avatar
If you don't have scanner run the car. With it running at idle unplug 1 COP at a time. If it runs rougher that COP is good. If the idle does NOT change the COP is BAD!
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 01-20-2012, 12:07 AM   #4
irishn8's Avatar
+1
right out of the book
Old 01-20-2012, 07:51 AM   #5
jjsg09's Avatar
That's how I found my c.o.p. was out
Old 01-20-2012, 08:08 AM   #6
Will that work when its not bad enough it is not giving any codes?
Old 01-20-2012, 04:04 PM   #7
Yes.
1994 Mustang GT
Old 01-20-2012, 04:27 PM   #8
Yes.
Ok thanks for the help I will try it Sunday.
Old 01-20-2012, 06:36 PM   #9
LAS97GT's Avatar
Hello folks,
Got a 97 GT convertible here. Building it with time and $, and lots of TLC. Got a down stream o2 sensor bad read from the ECU. Changed sensor but doubt fault will go away probably due to increased flow from BBK exhaust, CAT, & flow-M mufflers. Guru say after market tuning needed. Question is how long can I wait till do the tune? BTW I have a set of BBK Shorties to add...
Any advice welcome.
---Las
---------- Post added at 08:36 PM ---------- Previous post was at 08:29 PM ----------
Forgot 1 thing, problem started after BBK mod. Also, the fault was read via scanner.
Thanks.
Las
---Las97GT
Old 02-03-2012, 12:38 PM   #10
irishn8's Avatar
No rush
Old 02-03-2012, 01:27 PM   #11
Originally Posted by irishn8
No rush
I ended up not checking them, the car has been doing fine now for some reason.
Gas cap check engine vinnygt SVT Mustang 9 12-16-2011 04:00 PM
Check Engine Question PonyBoyV6 Pre-2005 V6 Mustang 13 09-20-2011 03:35 PM
What is a good way to check the cowl ? crkmonzo 1979-1995 Mustang GT 3 09-13-2011 01:16 AM
having trouble help check engine light keeps coming on for the same code mustangsally696 General Car Discussion 2 08-18-2011 07:02 AM
'88 GT check engine light? robert81717 1979-1995 Mustang GT 7 07-12-2011 11:56 PM
03:33 PM
