Turn signals and breaklights not working - Mustang Evolution
Old 01-19-2012, 09:27 PM   #1
Genocide 99gt's Avatar
Turn signals hazards and break lights (excluding the 3rd break light) are not working. all the running lights and head lights work I checked the fuse and it's not blown
What do y'all think?
Genocide 99gt is offline   Reply With Quote
Old 01-20-2012, 12:18 AM   #2
irishn8's Avatar
Check wiring, there is a broken wire somewhere. Brake out the multimeter and a wiring diagram, it could literally b anywhere.
Old 01-20-2012, 08:28 AM   #3
aegischief's Avatar
Isn't there a relay for that as well as a fuse?
aegischief is offline   Reply With Quote
Old 01-20-2012, 10:24 AM   #4
Berbantor's Avatar
Yes theres a relay under the dash. Not sure witch one
2001 gt, 5speed. 70mm throttle body with stackracing plenum. bbk intake, 4.10 eaton posi, short shifter, o/r side exhuast.
Berbantor is offline   Reply With Quote
Old 01-22-2012, 12:20 AM   #5
Re: Turn signals and breaklights not working
Multifunction switch had to be replaced when mine acted similar. The fuses are next to the relay (big, yellow one). Fuse schematic printed on inside.
Old 01-27-2012, 05:22 PM   #6
Replaced the multifunction switch no luck and I can't find the turn signal relay switch can any one direct me to it and will this cause your break lights not to work? I think I have some sorta short or something
Old 01-28-2012, 12:01 AM   #7
irishn8's Avatar
Yes it can. I wouldn't be surprized at all if that fixed the problem. If u have a second car, u should test the components for proper operation before buying a new one. Throwing money at new parts and hoping it works isn't frugal. I know you don't mean to. See, I hear about these things all the time, where someone has a problem with their car and they just keep replacing parts and a few thousand dollars later they give up and sell the car.
Old 01-28-2012, 01:31 AM   #8
If you reach down, under the steering column, dead center, up and underneath you will feel a bracket with a yellow square turn signal relay. Next to that is some more fuses.
Old 01-28-2012, 05:49 AM   #9
02PONY's Avatar
Probably the boo switch "brake on/off" they're like 5-10$
02PONY is offline   Reply With Quote
Old 01-29-2012, 11:50 PM   #10
irishn8's Avatar
He said the third brake light works, so the stop switch works fine.
Old 01-30-2012, 12:18 AM   #11
02PONY's Avatar
I missed that part
02:36 AM
