5.4 - Mustang Evolution
Old 01-20-2012, 10:24 PM   #1
Tyler96gt's Avatar
5.4
Any opinion on a 5.4 swap? I have a pretty tight budget and I want my money to go far lol
Tyler96gt is offline   Reply With Quote
Old 01-20-2012, 10:40 PM   #2
DaBluedude's Avatar
Then to be honest, this swap is not for u.
2003 Mach 1
Old 01-21-2012, 08:59 AM   #3
Tyler96gt's Avatar
Why do you say that? If I can.find blocks that need rebuily for under 400 and I will be selling my 4.6 that will knock the block and re build
Old 01-21-2012, 10:02 AM   #4
02PONY's Avatar
You should be able to find a good 5.4 that doesn't need rebuilt for 400 or less. Got mine from wrecked truck for $100 And don't think you'll get enough for your 4.6 to buy and rebuild the 5.4. A stock rebuild is going to be 1500$ + These mod motors are not cheap to build u should just look into a 4v swap on your 4.6 I've seen head/intake combos for 200-500 everyday
02PONY is offline   Reply With Quote
Old 01-21-2012, 10:06 AM   #5
Tyler96gt's Avatar
Do you like the 5.4? I always lile to be different than the cobra swap s lol and I like the torque from the 5.4
---------- Post added at 11:06 AM ---------- Previous post was at 11:05 AM ----------
Oh amd I havent hit the local.junkyards im still in the planning phase so I could probably find one cheap
Old 01-21-2012, 10:21 AM   #6
Its alot of work id just go with a stroked 351w my self if u like torqu,e and u can get 5.8l dirt cheep be way torquer then a 5.4.
Hawk is offline   Reply With Quote
Old 01-21-2012, 10:24 AM   #7
Tyler96gt's Avatar
What would I have to do for that swap
Old 01-21-2012, 10:37 AM   #8
What trans do u have? Since ur a 96 that would make u the first yr of the 4.6l so ull prolly need a pcm out of a 95 or older or u can go carb and skip alot of electrical bs and ull prolly need new engine mounts and a trans bell housing to bolt up to the 5.8 that is if u have a t5 trans if u dont have a t5 or t56 ull want to get one (the t56 6speed can be built to handle over a 1000 hp) and depending on how u build a 351w ur good for 300-1200hp so deciding what kind of hp u want is going to determan were and how to save money in ur build ex if u can use a t5 trans or if u built it to strong and need a t56. The body style of ur car is very similar to mine and a dart block 351w is whats going in my ride. U dont need to cut up ur engine bay or fire wall at all to fit this small block in just need new engine mounts.
Old 01-21-2012, 10:52 AM   #9
02PONY's Avatar
I have not put 5.4 in. It's a project motor someday lol. Yes a 5.0 or 5.8 swap would work if u get PCM also and they are cheaper to build up
5.4 engine swap problem victory181 1996-2004 Mustang GT 3 01-01-2012 03:15 PM
Anyone here done the 5.4 swap? victory181 1996-2004 Mustang GT 6 12-29-2011 05:24 PM
5.4 motor in 65 Dmay65 Classic Mustangs 17 12-05-2011 09:40 PM
5.4 modular swap HPS intake ?? victory181 1996-2004 Mustang GT 0 10-27-2011 06:12 PM
Starting my 4.6 to 5.4 prep and swap! Scarreddragon 1996-2004 Mustang GT 36 10-20-2011 10:40 PM
11:40 PM
