Problem with OBD Code P0455 - Mustang Evolution
Old 01-21-2012, 08:17 PM   #1
Thumbs up Problem with OBD Code P0455
Hello everybody, especially Nickysixx. I just want to give an update. Back in Sept. I posted a problem with the evap. system on my 2002GT the code from the scanner (P0455) indicated it was a large leak. After a lengthy and thorough inspection, and several conversations with Nickysixx (thanks) I was not able to find the culprit. So, I decided to wait. My tags were up for renewal so I took it to the local Shell Station/Smog Inspection, and for $120 plus parts, the mechanic there found and fixed the problem. The problem was the Vapor Canister Purge Valve which is located behind the pass. side front fender wall. I guess this valve controls the fuel vapors between the engine and the gas tank. Again, I just wanted to post an update and a piece of info. to assist other folks who may experience this problem. This valve runs $67 at Ford's and about 2/3 the price, or around $40 if you go aftermarket. Thanks again, Nickysixx for your help and thanks for this website.
tonyjuan is offline   Reply With Quote
Old 01-23-2012, 04:52 PM   #2
AgentOrange's Avatar
Very good to know, as I have that same code and its driving me nuts. Ill set aside some time and test mine tomorrow!
AgentOrange is offline   Reply With Quote
Old 01-23-2012, 10:28 PM   #3
Re: Problem with OBD Code P0455
You have to remove the tire, I think is located above the tire towards the front. Find out how to test it to make sure. Good luck.
EVAP Help P0455 CEL and now random misfiring 3ntr0py Pre-2005 V6 Mustang 11 01-24-2012 01:37 PM
August Forum-Only Discounts from AmericanMuscle.com! AMChrisRose AmericanMuscle 28 10-15-2011 01:24 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
CEL and code P0442 TwoSeveN 2005-2010 V6 Mustang 6 08-16-2011 08:15 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
12:13 PM
