off road x or H pipe? - Mustang Evolution
Old 01-22-2012, 07:06 PM   #1
mcvicar04's Avatar
hey guys looking to upgrade my exhaust i am looking to run off road pipes, i have heard from ppl that mustangs run like shiiit if you put off road pipes on them because if the loss of back pressure is this true? and which is better x or H pipes
mcvicar04 is offline   Reply With Quote
Old 01-22-2012, 07:13 PM   #2
Cobrarunnin9s's Avatar
Re: off road x or H pipe?
First off, whoever told you that you need backpressure in your exhaust is an idiot. Backpressure means there is a restriction in your exhaust. Either mid-pipe is good, the way it sounds is gonna be the only noticeable difference.
Cobrarunnin9s is offline   Reply With Quote
Old 01-22-2012, 07:16 PM   #3
Eturner's Avatar
Originally Posted by Cobrarunnin9s
First off, whoever told you that you need backpressure in your exhaust is an idiot. Backpressure means there is a restriction I your exhaust. Either mid-pipe is good, the way it sounds is gonna be the only noticeable difference.
+11
I have an o/r X-pipe on my car and it actually runs alot better without the cats!.. I would also suggest getting a tuner for it if you had not already done so!..
Old 01-22-2012, 07:18 PM   #4
mcvicar04's Avatar
Thank you
Old 01-22-2012, 07:23 PM   #5
jjsg09's Avatar
This is my set up.
Old 01-22-2012, 07:25 PM   #6
Eturner's Avatar
Originally Posted by mcvicar04
Thank you
No problem!...
I did a post a while back about the myths of back pressure!.. It has three good wright ups that I found!.. If you have some time (like 20min, it is kinda lengthy) I would suggest reading it!... Lol
Old 01-22-2012, 08:13 PM   #7
Doe_Rae_mi's Avatar
O\R x pipes are more raspy then the H pipes. Which sounds amazing IMO
Old 01-23-2012, 08:20 AM   #8
shsfresh87's Avatar
Region: West Virgina
Depends on ur exhaust, the hpipe will make it sound deeper which goes great with flowmasters
shsfresh87 is offline   Reply With Quote
Old 01-23-2012, 08:59 AM   #9
mcvicar04's Avatar
I'm going to be running the maganflow cat back ( not the magnapaks )
Old 01-23-2012, 11:52 AM   #10
JetLife 01GT's Avatar
I think most people agree that the x flows a bit better but the difference of flow between x and h is pretty minimal. It's all depends on if you want a deeper tone or a bit more raspy of a sound. They're both just as loud as the other. The sound they make is just a bit different. Also many people like the prochamber. It has a different sound than the x and h, so that may be something you want to check out as well
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 01-23-2012, 12:14 PM   #11
Eturner's Avatar
They are both actually equal in their own right!.. The H is good for a bit more low end power!.. The X is better on top!...
Old 01-23-2012, 12:18 PM   #12
MAC pro chamber ftw!!!
Hawk is offline   Reply With Quote
Old 01-25-2012, 05:22 AM   #13
mcvicar04's Avatar
Hey guys I am getting paid on Monday and I think I am going to buy the x pipe but should I wait to put it on, because right now my exhaust is stock. Will I have to get it tuned? Or will it be fine and just have the check engine light on?
Old 01-25-2012, 06:11 AM   #14
Eturner's Avatar
It will be fine, but I would suggest getting a tuner as soon as you can!..
Off road h pipe David Cope 2005-2010 Mustang GT 5 01-02-2012 08:45 PM
off road x or h pipe require tune? jwhayne0001 1979-1995 Mustang GT 9 11-16-2011 01:42 PM
what is an off road pipe? GoldenPonyBoy 2005-2010 Mustang GT 9 11-05-2011 10:24 AM
Off Road H Pipe ssaleen1981 Pre-2005 V6 Mustang 0 10-27-2011 06:32 AM
off road x pipe secomejia 1996-2004 Mustang GT 6 08-27-2011 07:39 PM
06:25 PM
