Thinking of Brakes - Mustang Evolution
Old 01-24-2012, 06:37 PM   #1
jjsg09's Avatar
Thinking of Brakes
I'm looking into putting new brakes on my 02 Stang. I was on Summit Racing and saw Power Stop cross drilled and slotted rotors for the front and rear of my car. Im kinda on a budget and these rotors look nice. Does anyone know if these are good, my car is a DD and is getting close to needing new.
Old 01-24-2012, 06:51 PM   #2
Mile high JDF's Avatar
My friend just put them on his 95 GT. he says they stop pretty good. Personally I put Power Slot rotors on my car and those stop great as well.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-24-2012, 07:20 PM   #3
BigB227's Avatar
I as well got the hawk power slots and they work great. My cars also a DD
BigB227 is offline   Reply With Quote
Old 01-24-2012, 07:29 PM   #4
03GT88's Avatar
i would guess there pretty good. have you thought about getting cobra brakes? Thats what i upgraded to with ebc yellow pads. they look and perform great. i think i paid either 150 or 200 cant remember.
03GT88 is offline   Reply With Quote
Old 01-24-2012, 07:53 PM   #5
jjsg09's Avatar
Did you have to modify the caliper location for the cobra brakes. Aren't they bigger?
Old 01-24-2012, 07:59 PM   #6
DaBluedude's Avatar
Yes. The cobra upgrade requires new mounting brackets, rotors (obv), and brake lines. You can use the stock master cylinder but I seriously upgrading it too. I believe it is also recomended you change your traction module to a cobra one but I'm not sure on that.
2003 Mach 1
Old 01-24-2012, 08:22 PM   #7
jjsg09's Avatar
Well I'm kinda on a budget for this project and that job sounds like its costly. Thanks though
Old 01-24-2012, 09:47 PM   #8
03GT88's Avatar
no brackets or modifications were necessary. i simply replaced my 2003 gt rotors and calipers with 2003 cobra rotors and calipers. direct replacement.
---------- Post added at 11:47 PM ---------- Previous post was at 11:45 PM ----------
i only upgraded the front btw
Old 01-25-2012, 08:07 AM   #9
jjsg09's Avatar
Do you have any pics of those brakes?
Old 01-25-2012, 10:46 AM   #10
Re: Thinking of Brakes
slotted/drilled dont do anything for stoping better/faster. They do however wont last as long, cant be turned, and warp much easier depending on how they are made
I would upgrade to 13" cobra brakes/rotors/ss brake lines on the front and paint the calipers, much much better braking for a cheap price
Old 01-25-2012, 11:40 AM   #11
DaBluedude's Avatar
^ this I disagree with. The drilled and slotted rotors I've used made a big difference in stopping power and pedal feel. Warping has more to do with break in and how you use your breaks. The drilled slotted I use also resist fade longer at the track by a considerable margain. I also find the pad bite to be much improved.
2003 Mach 1
Old 01-25-2012, 12:22 PM   #12
irishn8's Avatar
I wouldn't use drilled and/or slotted on a DD as it consumes your brakes faster and does not allow you to turn the disks. It cost more now as well as later and simply isn't needed for daily driving.
Old 01-25-2012, 01:14 PM   #13
03GT88's Avatar
Old 01-25-2012, 07:24 PM   #14
I bought some from summit racing for the front two years ago and every winter and spring the blizaks comes off and back on. Approximate miles driven is 15k and the slots are have 30% remaining life. Roughly .015 they wareout like sanding the plaster to get rid of a bubble on your drywall. That's the best way I can really explain what it looks like. The set next to buy will be the actual drilled through style.
Gtif is offline   Reply With Quote
Old 01-26-2012, 07:32 AM   #15
jjsg09's Avatar
I would love to do the cobra bakes but I'm kinda on a budget and need to just get new brakes.
Old 01-26-2012, 08:20 AM   #16
Eturner's Avatar
You could just do Steal Braided lines on your brakes!.. That's what I did for now and it helps some!...
Old 01-26-2012, 09:55 AM   #17
you can buy used cobra brake parts for VERY cheap. I sold my stock calipers and brake lines for 75 bucks, all thats left is rotors and your good to go (well possibly pads if the calipers didnt have any with them)
Old 01-26-2012, 10:27 AM   #18
jjsg09's Avatar
Ok thx I'm gonna be looking into it then. Hey I was also told to look into the bullitt brakes.......know anything about that.
Old 01-26-2012, 10:36 AM   #19
DaBluedude's Avatar
There the same deal as the cobra brakes.
2003 Mach 1
disc brakes jacob.a.gasparp 1979-1995 Mustang GT 4 01-24-2012 05:11 PM
Brakes avengnd 2011-2014 Mustang GT 10 12-27-2011 09:46 PM
Thinking About Getting a Stang.. GT500E General Mustang Discussion 20 10-21-2011 03:00 PM
New Brakes Timm04 Pre-2005 V6 Mustang 6 09-22-2011 01:28 PM
conversion disc brakes? 1faststang Classic Mustangs 15 08-11-2011 01:30 AM
02:12 PM
