pcv valve - Mustang Evolution
Old 01-24-2012, 10:49 PM   #1
Berbantor's Avatar
pcv valve
Well as my Car is running There is a loud hissing sound from the pcv valve. The line and valve are new. Now Its a 2001 gt. Can i just put a breather filter on it. Where can i get one and Wat do u rec.
2001 gt, 5speed. 70mm throttle body with stackracing plenum. bbk intake, 4.10 eaton posi, short shifter, o/r side exhuast.
Berbantor is offline   Reply With Quote
Old 01-25-2012, 01:11 AM   #2
irishn8's Avatar
No, u need that. Play around with it, see if u can find exactly what is causing the hissing. Mine doesn't hiss so...I'm sure urs shouldn't.
Old 01-25-2012, 04:51 AM   #3
Berbantor's Avatar
I worked on a 04 gt and it had the filter on it
Old 01-25-2012, 10:59 PM   #4
Berbantor's Avatar
I have a oil catch can hooked up to it. But my hoses r rubber could they be colapsing. What kind of hoses Would u rec.
Old 01-25-2012, 11:21 PM   #5
irishn8's Avatar
Oh they aren't stock? U need vacuum hoses, I believe any car parts store has it, I know NAPA does.
Old 01-26-2012, 05:17 AM   #6
Berbantor's Avatar
Alright Ill Give it a shot. Thx
Old 01-26-2012, 09:58 AM   #7
Re: pcv valve
you can put a breather but you will be letting un-metered air into the engine~ just an FYI
Old 01-26-2012, 09:43 PM   #8
Berbantor's Avatar
Wat if i plug the hole going to the throttle body
Old 01-26-2012, 10:15 PM   #9
irishn8's Avatar
Re: pcv valve
instead of the vacuum hose?
Old 01-26-2012, 10:59 PM   #10
Berbantor's Avatar
Yes use a breather filter. Then were the hose connefts to the throttle body just put something in the hose to block it
Old 01-26-2012, 11:11 PM   #11
irishn8's Avatar
Re: pcv valve
or if ur throttle body has a nipple, put a plug on that. all the PCV does is direct the gasses that have escaped from your cylinders to ur crank case from entering the atmosphere without being burned.
Old 01-27-2012, 06:32 AM   #12
Berbantor's Avatar
Were Would i get one for an 01 gt. And Wat style Push in or screw in. Plus will it hurt my engine
PCV Hose jjsg09 1996-2004 Mustang GT 5 01-17-2012 10:21 PM
Egr valve Matt5.0 1979-1995 Mustang GT 5 01-02-2012 09:15 PM
Pcv valve Jpstang 1979-1995 Mustang GT 5 11-26-2011 09:55 AM
PCV Valve MustangGT02 1996-2004 Mustang GT 1 08-27-2011 08:46 AM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
11:27 AM
