Amber Lens in Headlights - Mustang Evolution
Old 01-26-2012, 06:07 PM   #1
MiGT01's Avatar
Has anyone attempted to try and just break the 3 amber lens in peices out of the HL before? I have done this on many cars and looking at it, it looks possible. The ones Ive done this with still had the amber turn signal bulbs so the purpose is still there just the lens are not. Almost like ALL clear headlights.
01 Black Beauty GT
Eibach pro kit,Tokico shocks/struts,BBK CAI,75mm TB/ Plenum,4.10 FRPP gears,BBK o/r X pipe,Magnaflow Catback,SCT Tuner running 91 Tune,Bama Tunes for Life Member,RAM HD Clutch,BM shifter with MGW "GT" knob,AM smoked Headlights/Sylvania zXe bulbs,VHT smoked tails/3rd brake,Redtop Optima,Mach 1 grille delete,Mach 1 chin spoiler,BULLITT Pedals,20% tint all round,4.6 High Performance Badges
MiGT01 is offline   Reply With Quote
Old 01-27-2012, 06:19 PM   #2
MiGT01's Avatar
Re: Amber Lens in Headlights
Guess not, Whelp, Looks like ill attempt it and post em up!
01 Black Beauty GT
Old 01-27-2012, 07:20 PM   #3
Gotta give us a few... Heat the housing in oven slightly then pull outer lense off and remove the amber. Reseal well w silicon and enjoy
Old 01-27-2012, 07:23 PM   #4
deadsp0t's Avatar
Herd 200-250*.. Ask toplessGT he has done some like yours
That's unimpressive
Old 01-27-2012, 07:55 PM   #5
MiGT01's Avatar
I only replied cause i searched threads and didnt find any. Figured a "bump" would be okay to find answer...seemed to have worked....Like i said ive done this before...on other cars...not sure if those reflectors are glued into inner housing or clipped in somehow...ive taken housings apart and in some cases broke the reflectors into pieces and pulled out. Wanted to see if someone has done it before is all
01 Black Beauty GT
Old 01-27-2012, 10:44 PM   #6
Torrbo916's Avatar
If the hl are aftermarket then they should. It isn't 3 little pieces. It's actually one piece that the three ambers clip into. If so then it's probably tack glued in 4 spots. That's how my wife's aftermarkets were. If you bake them to pull apart then do the same to put back together then silicone the seam.
---------- Post added at 12:44 AM ---------- Previous post was at 12:40 AM ----------
You should paint to match while they are apart.
Torrbo916 is offline   Reply With Quote
Old 01-27-2012, 10:45 PM   #7
Torrbo916's Avatar
Old 01-27-2012, 11:50 PM   #8
Topless04GT's Avatar
here ya go bub. just *** in the removal of the amber while your in there. or just paint them black, or whatever you need to do.
Hope this helps
How To: Paint Your Headlights in 15 Easy Steps (oven bake method)
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 01-28-2012, 09:44 AM   #9
MiGT01's Avatar
Guess my search didnt work because titled different. So Id just have to take em apart pretty much. Paint or try and remove them then. Ill grab my heat gun from storage this weekend! Thanks Josh!
01 Black Beauty GT
Looking for headlights jkaminski24 Pre-2005 V6 Mustang 3 01-08-2012 12:27 AM
Halo Icis Cool Blue Headlights!!!!!! Topless04GT Mustang Paint, Appearance & Detailing 5 12-21-2011 01:17 AM
How To: Paint Your Headlights in 15 Easy Steps (oven bake method) Topless04GT Mustang Paint, Appearance & Detailing 6 12-11-2011 04:46 PM
restore yellow burnt headlights cheap 1988_gt_5.0 General Mustang Discussion 10 10-15-2011 03:24 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
12:01 PM
