Two slight problems - Mustang Evolution
Old 01-28-2012, 04:34 PM   #1
86 muscle's Avatar
Two slight problems
Well I left my car this morning got back out and noticed I've got a bit of a leak coming from right around the filter, now I'm a big guy and couldn't crawl under to investigate fully but it looks as though its coming from the filter area? Any ideas there?
The second problem, while driving coming off the interstate I noticed I pulled it out of 5th gear and it basically went straight into reverse?! It didn't actually go into the gear cause I didn't stop it but it didn't stop itself! Any help on these two areas would be great!
86 muscle is offline   Reply With Quote
Old 01-28-2012, 10:42 PM   #2
LAS97GT's Avatar
Re: Two slight problems
Ok, sounds like a prob I had a while back. sounds like you have an oil cooler between your oil filter and the engine block (I did not do any research to your eng spec). If you do, you need to remove the oil cooler (cobra spec) and push the plunger a few times to free it up. You will notice a small seep hole opening on the cooler housing; its blocked (the plunger inside the housing, not the seep hole). Finding a replacement is difficult, very. clean it best you can and reinstall.finidng a new O-ring gastket is advisable but not required. Essentially, oil blows by when the plunger is clogged. I fixed mine as stated above. Like I said, I did not research your car due to cost. come back when you can. Get it on a lift and check. Its an easy fix. the plunger in the cooler is not worn, just plugged, that should stop the leak.
las97GT
2000 V6 problems iphonemaster93 2.3 Mustang 47 01-12-2012 12:10 AM
Misfiring problems Stockish302 1979-1995 Mustang GT 14 11-15-2011 01:08 PM
Self installing the boss 302 mani! Any advice or problems anyone has run into? Benzo 2011-2014 Mustang GT 6 10-03-2011 05:23 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
08:59 PM
