02 Gt convertible map lights - Mustang Evolution
Old 01-28-2012, 07:59 PM   #1
Venemous02GT's Avatar
My map lights won't turn out so I had to pull the fuse and now have no interior lights. I know it isn't the fuse Does anyone know what problem is, whether its wiring or another issue? Im trying to avoid taking it to the dealer and paying too much.
Venemous02GT is offline   Reply With Quote
Old 01-28-2012, 08:20 PM   #2
I would think it's either the switch in it or the map light itself. I would try to find another map light at the junk yard instead of taking it to the dealer
Robbie94gt is offline   Reply With Quote
Old 01-28-2012, 11:16 PM   #3
Yeah I'll try to find another map light at a junkyard. I'm tryin to avoid the dealer at all costs. Haha
Old 01-29-2012, 07:04 AM   #4
Funny, dealer's cost
Gtif is offline   Reply With Quote
Old 01-29-2012, 08:12 AM   #5
Haha yeah
Old 01-30-2012, 09:30 AM   #6
2002VertGT's Avatar
I would check the door switch....or even the headlight switch...some people forget that if you turn that all the way to the right they come on....there is another thread on here where someone had this prob with a coup and it was the door switch that tells that the door is closed...
Most likely not your map lights, don't waste the $
---------- Post added at 11:30 AM ---------- Previous post was at 11:28 AM ----------
This Is the problem identifier and solution if its the door switch...
Originally Posted by vevo08
I had the same problem... There is a door sensor, if you take WD 40 and spray where the door closes it will clear your problem.
Hope this helps.
Originally Posted by Frankensteins
When you close the doors and hit the lock bottom on your key fab, does your horn beep once or twice? If its twice...then the car thinks that one of the doors are still open. And to fix that you have to find the "open" door and replace the bottom hinge, thats where the open close switch is.
4.10 Gear/RPM thread
99 Gt Convertible Top Problems FORDGT14 1996-2004 Mustang GT 2 12-20-2011 10:06 AM
2006 GT 350 theivanoff 2005-2010 Mustang GT 15 09-20-2011 05:16 PM
My first burnout video with 2010 GT convertible martynas Mustang Audio & Video 15 07-26-2011 08:57 PM
Gt and Lx convertible robert81717 1979-1995 Mustang GT 5 07-26-2011 07:04 PM
01:09 PM
