Springs - Mustang Evolution
Old 01-31-2012, 03:59 PM   #1
01StangGt's Avatar
Springs
Plan on dropping my car, just thinking of b or c springs, daily driver car
---------- Post added at 05:59 PM ---------- Previous post was at 05:59 PM ----------
Also street as well
01StangGt is offline   Reply With Quote
Old 01-31-2012, 08:04 PM   #2
GP3GT's Avatar
Re: Springs
me too, AM has the H&R supersport springs that look like a good enough drop..i think there on sale for like $225..
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
GP3GT is offline   Reply With Quote
Old 01-31-2012, 08:10 PM   #3
01StangGt's Avatar
I'm not sure which to go with, b or c? Not 100 percent what the difference is, but I'm not looking for a HUGE drop maybe like 1 and a quarter all around
Old 01-31-2012, 08:17 PM   #4
GP3GT's Avatar
Re: Springs
Just compare them on AM, or pm the AM guy Chris Rose..im sure he would be able to tell you the difference of both of them.
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
Old 02-01-2012, 09:55 AM   #5
04GTRed_Plague's Avatar
The only diff between the b and the c is the spring rate. the b is a gonna be a little softer up front then the c springs but the drop is the same. Are u changing shocks and struts?
04GTRed_Plague is offline   Reply With Quote
Old 02-01-2012, 11:12 AM   #6
Re: Springs
stiffer ride = c springs (but better handling) b springs I dont think give as good of a drop but they may, they are softer (near stock spring rate)
also, some C springs need to be cut some do not.
Old 02-01-2012, 05:10 PM   #7
LAS97GT's Avatar
Re: Springs
I'll toss my set I for 150. Totally low. My 97 GT Convertible was sitting 3 inches off the floor at the cats. Was pebble dodging. Mind you, I have a convertible, heavier! Could get your stang sittin higher than you want and ride harder too.
---Las97GT
Old 02-01-2012, 06:01 PM   #8
01StangGt's Avatar
Ok that's what I thought the difference was just wanted a second opinion, my car is my daily driver, but if a tuner pulls up next to me and wants to cruise then it's my street car, stiffer springs result in more torque to the tires and less squatting, better launching. I just replaced the rear shocks, while doing this lowering process I am going to swap out the front struts, which one, I'm still debating on which to get. Deff going to get the camber caster plates, that's a must, it was springs or a tuner. I pick the springs, one cheaper, two it makes the car look totally sick. The tuner will be next on my agenda.
Old 02-02-2012, 11:09 AM   #9
Idk if it is necessary but i would keep the shocks and struts the same brand and model. Im sure u can mix and match but its gonna be that much harder to make sure u get a good match as far as damping and spring rates go... i guess anyway i could be wrong but thats just my opinion.
---------- Post added at 01:09 PM ---------- Previous post was at 01:03 PM ----------
Oh yea and the caster camber plates aren't always needed... i would lower and get it aligned to see if u need then.. with the ford springs they say 1.25in drop so i would think u could get away with out them. I have Eibach sportlines and i didnt need the plates. The shop got me within a degree of factory specs and im going to go with the camber bolts.. there only like $30 and they correct alignment up to a full degree
Lowering Springs jjsg09 1996-2004 Mustang GT 14 02-06-2012 06:11 AM
55D Springs on Brembo Brake Mustangs 201150300A 2011-2014 Mustang GT 0 12-13-2011 05:16 PM
lowering springs stangaroo 2011-2014 Mustang GT 23 11-13-2011 07:43 AM
Lowering springs 89white GT AmericanMuscle 1 08-30-2011 04:11 PM
Lowering springs. GoldenPonyBoy 2005-2010 V6 Mustang 13 07-26-2011 06:40 PM
04:42 AM
