Convertible top problems - Mustang Evolution
Old 01-31-2012, 09:22 PM   #1
Ajhboy94's Avatar
Today I put my top down in my 97 gt. and when I went to go put it up it didn't work. The motor doesn't make a sound. However it still makes a sound when I push the down button. I've checked the fuses in the fuse box under the hood and they're fine. Any idea what the problem is?
Ajhboy94 is offline   Reply With Quote
Old 02-02-2012, 08:02 AM   #2
2002VertGT's Avatar
Hmmm....either motor only works in down or you got hydraulic problems....motor should still make sounds... *pondering*
4.10 Gear/RPM thread
Old 02-02-2012, 02:11 PM   #3
Ajhboy94's Avatar
Is there a way to manually put it back up? I don't want to do anymore damage and I can't put it into the mechanics until monday
Old 02-02-2012, 02:24 PM   #4
2002VertGT's Avatar
Not sure...it sounds like it could be the switch too....
Old 02-02-2012, 07:12 PM   #5
LAS97GT's Avatar
Re: Convertible top problems
I own an 97GT conv. as well. I have a very strong feeling that you will need to pull your center console. Pull the switch, get some electronic cleaner/lubricant and clean it. As you already know the switch sits directly under the extendable cup holder. Over a period of time the switch either sticks or does not work; gunk problems. clean it out and it should work again. if the switch is busted, then try doing it manually by jumping the wires to the mortor at the console area. I dont recall the number of wires but there should be 3 no more than four wires there. The lift mortor only functions in two directions fwd and rev. I think you get the idea. Its the switch becuase the motor runs. Good Luck. let me know how it turns out. Thanks.
---las
---Las97GT
Old 02-02-2012, 09:13 PM   #6
Ajhboy94's Avatar
For now I was able to pull the top up manually. I'll check out the switch this weekend when I have time
Old 02-02-2012, 11:03 PM   #7
2002VertGT's Avatar
Good ****
Old 02-03-2012, 03:02 PM   #8
Ajhboy94's Avatar
It was the switch. A wire had just fallen off of it. Thanks
Old 02-03-2012, 03:10 PM   #9
2002VertGT's Avatar
No man glad it is fixed and it was a cheap fix!
Old 06-09-2015, 10:03 PM   #10
Angry 97 Manual Mustang GT Convertible Top Problems
Good Day!
I have a 97 Mustang GT and my convertible top stopped working today just suddenly. It worked fine every other day
I pressed the button and it went down fine. However, when I pressed the button to go down or up it makes no sound and wont move. The car is in Netural,emergency brakes is all the way up, car is off - it works fine like this all the times. Do anyone know my problem? Everything else works fine. Can it be a blown fuse?
Help! HelP! Help! Please....
I am bugged.
tanthonyv is offline   Reply With Quote
Old 06-10-2015, 05:46 AM   #11
Well if you read this thread, that you bumped after 3 years there was already some solid advice for you.
HELP! New Convertible Top MustangGod 2005-2010 Mustang GT 2 12-29-2011 06:54 PM
99 Gt Convertible Top Problems FORDGT14 1996-2004 Mustang GT 2 12-20-2011 10:06 AM
05 convertible top tension cable location kingpeng0318 2005-2010 V6 Mustang 0 10-10-2011 12:33 AM
Convertible Top Pump with Metal Shavings Xexyz General Mustang Discussion 1 08-12-2011 06:26 AM
05:39 AM
