Signs of a bad clutch? - Mustang Evolution
Old 02-02-2012, 01:21 AM   #1
FORDGT14's Avatar
What are some usual signs of a clutch going bad?
FORDGT14 is offline   Reply With Quote
Old 02-02-2012, 03:06 PM   #2
Doe_Rae_mi's Avatar
Hearing it wine when you press down on it to switch the gears
Old 02-02-2012, 07:33 PM   #3
LAS97GT's Avatar
Re: Signs of a bad clutch?
Heck of whine when the through-out bearings are totally busted and no lube on the tranny shaft, all bearings missing from racer. I rescued mine when I bought it. Pulled it off gently with a flywheel puller. Drove it only to the house after purchase, and then directly to the auto skills center (military perk).
---Las97GT
Old 02-02-2012, 08:34 PM   #4
SSC182's Avatar
Clutch slippage hard to get into all gears
---------- Post added at 11:34 PM ---------- Previous post was at 11:31 PM ----------
What do you mean by the tranny shaft and bearings missing from racer I've rebuilt several manual transmissions and have no Idea what your talking about
SSC182 is offline   Reply With Quote
Old 02-02-2012, 11:02 PM   #5
Mustang_Madness's Avatar
It is hard to get my car into 5th gear. ill push the clutch all the way down, but it'll grind the gears briefly to get it in. It gets kinda hard to get it into all the other gears as well, just not as bad. i have a new clutch line and quadrant so those aren't whats wrong...help?
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-03-2012, 12:27 AM   #6
irishn8's Avatar
On the side of ur clutch is a lever that ultimately connects to ur clutch pedal. On the inside of the clutch that lever connects to a bearing that separates the clutch plates. the outside of that bearing sometimes goes bad so the lever moves but doesn't separate the plates. It shoud be an inexpensive fix. The other posibility is your sycros are bad, but that is less likely. I would asume its the clutch for now.
Old 07-12-2014, 10:18 AM   #7
idk. meh. so confusing. It could be glazed....
So, I'm a computer person. I was driving along and zip! crank!
I adjusted it using the factory method of pulling on the pedal. fale.
I put myself under there and looked at it. Just press the small one out to disengage the teeth and put it back where it's supposed to go. fale.
Zip ! Too much tension between the spring and the quadrant.
I mean, I looked under there at the clutch, put a nick in it where the fork position was... lol and adjusted it higher on the quadrant. (mor slack)
I went back under there... (phear) and the fork moved an entire 1/2 an inch. wtf! So tell me, what is the advantage to engage the clutch mechanism at all?
Ride on a spring +++ (a spring between the clutch bell and the fork) lol
I removed the tension spring on my clutch quadrant so it would go all the way back to release the clutch fork engagement point...
The trick will be to find a unique spring to use. One that looks like your cat would probably be good. lol
kk. It's hosed. It starts slipping going up a hill in 3rd gear with this rig:
Other than that it shifts very nicely. ++ I guess it's just hosed. No more 100mph++ Or long road trips unil it's fixed. If it is glazed, I hear that it should fix it's self; but whatever... In my other car, I was driving down the interstate at 65mph, (slip) then 55 mph, (slip) and finally 50mph before I got to where I was going so, seems to me it should just lock up, but it doesn't. Maybe it will fix it's self with the new arrangement.
sssquirrel is offline   Reply With Quote
Old 08-09-2014, 11:41 PM   #8
update ftw ... lol by some freakish chance you are able to re-engage your clutch, there is good news; mine corrected it's self!!! 8/10/2014 ... (250mi.)
Old 08-10-2014, 05:48 AM   #9
parkerz28's Avatar
Wow looking at where you placed your jack to jack up your car almost made my cry bro... Seriously
Sent from the back seat
parkerz28 is offline   Reply With Quote
Old 08-10-2014, 05:49 AM   #10
parkerz28's Avatar
^ me cry
Old 08-10-2014, 07:29 PM   #11
expensive place to jack it up. ยง
Old 08-11-2014, 11:10 AM   #12
Um.... yeah learn where your jacking points are... That is damn near destroyed. If you keep jacking there you are going to need to do some cutting/welding pretty soon...
Also yank that junk spring out of there if you didn't already and properly adjust your clutch cable. Some idiot installed that spring at some point under the false belief that there needs to be an air gap between the TOB and the clutch fingers. There doesn't.
Old 08-12-2014, 10:47 AM   #13
Pancakes's Avatar
You can try the higher gear test. Put the car into 4th or 5th and start it. Let off the clutch and see if it stalls. If it doesn't, your clutch is bad. Not sure if this method works on mustangs but it does on imports.
Pancakes is offline   Reply With Quote
Old 06-27-2015, 10:00 AM   #14
update
conclusion... it's definitely glazed and don't forget to put a piece of cardboard or something on the quadrant plate to adjust the clutch pedal height about even with the brake pedal....
If the fork is let out all the way it doesn't work....
Old 06-27-2015, 02:08 PM   #15
Mile high JDF's Avatar
Holy dead thread revival
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 06-27-2015, 03:14 PM   #16
I wonder at times if people can actually read dates........
Old 06-27-2015, 03:17 PM   #17
I just chalk it up to people actually using the search function.
Old 06-27-2015, 03:19 PM   #18
True.
Signs of a bad oxygen sensor 04machazblue 1979-1995 Mustang GT 33 01-24-2012 04:10 PM
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
Clutch eouellette18 2005-2010 Mustang GT 9 09-08-2011 03:51 PM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
05:13 PM
