Does anybody know how to shift without using the clutch? - Mustang Evolution
Old 02-02-2012, 03:43 AM   #1
SwatKatz901's Avatar
How is it even possible?
SwatKatz901 is offline   Reply With Quote
Old 02-02-2012, 04:09 AM   #2
It's not me, it's you.
primer2tone's Avatar
Yeah, it's possible but not recommended. When you match the engine RPM's with the transmission RPM's you can change gears without using the clutch. Cars have synchronized transmissions and Floating will wear out those synchronizers prematurely.
Old 02-02-2012, 05:21 AM   #3
Beav's Avatar
Re: Does anybody know how to shift without using the clutch?
Large trucks like semis do not have synchronizers and you must match rpm when you shift; some guys double clutch, but most truck drivers don't use the clutch except for starting and stopping...
Like he said above, you can shift a car without a clutch, but it's hard on synchros and I'd only do it in an emergency, like limping a car home with a broken clutch linkage.
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 02-02-2012, 07:06 AM   #4
Oh ok cool... I was asking because I've seen it on YouTubea while back and last night I accidentally did it going into 4th
---------- Post added at 08:06 AM ---------- Previous post was at 08:03 AM ----------
So I really needed to knowing, do him there have to major problem
Old 02-03-2012, 01:17 PM   #5
AgentOrange's Avatar
If you want to experiment with this use 5th gear. If your car has a stock ring and pinion you should be able to hit about 50 in fourth, clutch and put the car in N, then wait for the revs to drop (1100 or so) and apply light pressure to 5th. Since the RPM's are static you shouldn't have to make your synchros do the work. Should be butter. Don't make it a habit, but this is a safe..ish method to see how it works.
AgentOrange is offline   Reply With Quote
Old 02-03-2012, 02:17 PM   #6
many do this at the drag strip, many also replace transmissions from this
Old 02-03-2012, 03:52 PM   #7
I thought there was something bad about doing it that way... But I won't be trying it
Old 02-03-2012, 04:15 PM   #8
Nobody here is saying it isn't bad for the transmission.. I wouldn't do it much, just trying to give you an easy way to test it and learn the mechanics. You won't blow the tranny out of the bottom of the car or anything, its just bad for your synchros.
Old 02-03-2012, 04:55 PM   #9
LAS97GT's Avatar
Sounds right, since 5th is the overdrive that allows up to 45 engine safe function up to 45mph, did I get this right?
---Las97GT
Old 02-03-2012, 08:42 PM   #10
Blogger
99ford's Avatar
I think everyone should do this we would never have to worry about a recession ever again.
Old 02-03-2012, 08:47 PM   #11
gqsmash's Avatar
You can do it at low speeds too...I've the done higher speeds but I'm not as good and I don't want to mess anything up
gqsmash is offline   Reply With Quote
Old 02-04-2012, 04:05 AM   #12
DaBluedude's Avatar
Its nicknamed perfect shifting... and its just rev matched shifting... there are race transmissions available that work like this... its a fun trick and its a good skill. You can shift up and down like this but you will go through syncros...
2003 Mach 1
Old 02-20-2012, 12:36 AM   #13
LAS97GT's Avatar
Ask your personal mechanic that sold you your Stang, CRP Mod 4.6 Ltr. Rare model. Good Luck.
---Las97GT
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
04 cobra shifting problems NickGeezy General Mustang Discussion 7 09-21-2011 10:41 AM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Spec or ram clutch 04machazblue 1996-2004 Mustang GT 3 08-23-2011 04:36 PM
02:22 PM
