Ticking Noise - Mustang Evolution
Old 02-02-2012, 08:11 PM   #1
Cervantes107's Avatar
Ticking Noise
My stang is making a ticking noise at about 2500 rpm. It's been doing this for 6 months and hasn't gotten any worse. It doesn't tick all the time, and is quiet when car is cold. I've been driving my car hard and haven't had any power loss. What can it possibly be? My tranny's schincronizer is going out to, can it be that?
Cervantes107 is offline   Reply With Quote
Old 02-02-2012, 08:16 PM   #2
Newline's Avatar
Does it have headers or an aftermarket ignition system ?
Newline is offline   Reply With Quote
Old 02-02-2012, 08:46 PM   #3
SSC182's Avatar
You might want to try a valve adjustment to start with. What's your tranny doing that makes you think a synchro is going bad and no the ticking would not be a synchronizer assembly
SSC182 is offline   Reply With Quote
Old 02-02-2012, 08:53 PM   #4
My tranny is having rough shifts into 2nd and 3rd
Old 02-02-2012, 09:02 PM   #5
SSC182's Avatar
Well 1st and second are on one synchro assembly and 3rd and 4th are on a different one so I'd be surprised if one blocking ring on each assembly is bad if I were you if check and make sure your shift linkage is adjusted properly if it's a hydraulic clutch make sure there is enough fluid and bleed the line if all is good there then you might have to dive deeper into the problem
High pitched engine noise whine cjd_1986 2005-2010 V6 Mustang 4 01-16-2012 11:34 AM
Ticking type noise back n a stang 2011-2014 Mustang GT 0 01-07-2012 10:19 AM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
Noise help! Dnraiders 1996-2004 Mustang GT 3 08-23-2011 07:15 AM
12:49 AM
