2002 GT; the idle isn't anything really rough or anything... Just shakes the car a bit and the exhaust changes audibly to an extent. Is this normal? It feels like it won't get any smoother.
Yes. That's sorta like it.AgentOrange said:My 04 GT mostly idles smooth, but gives me a random little bump every few seconds, not much just enough to notice if im paying attention. Is that what you are experiencing?
Mine does it too and my last 01 GT did it could be trapped exhaust not getting out fast enough is what I've heard b4. I was suggested since I had so many bolt ons to get a set of better headers. Idk could be wrong.ColeJohnson said:Yes. That's sorta like it.
And I did all of that, Spector.
Def wrong. You don't need headers for bolt ons. Idk but anyway. Try cleaning the IAC and ur throttle body. Does it do it while your ac Is on or off??jjsg09 said:Mine does it too and my last 01 GT did it could be trapped exhaust not getting out fast enough is what I've heard b4. I was suggested since I had so many bolt ons to get a set of better headers. Idk could be wrong.
Where's the iac? And I never use my AC so idk if it does it while it's on.Jamesgt08 said:Def wrong. You don't need headers for bolt ons. Idk but anyway. Try cleaning the IAC and ur throttle body. Does it do it while your ac Is on or off??
Ok i said " what I have heard " don't be an ass about it.Jamesgt08 said:Def wrong. You don't need headers for bolt ons. Idk but anyway. Try cleaning the IAC and ur throttle body. Does it do it while your ac Is on or off??
Ok just thought it did but if it wasn't were cool.Jamesgt08 said:I wasn't bein an ass about. If u thought I was I'm sorry.
I fixed it. Found a vacuum leak finally. Replaced the hose and purrs like a kitten now.Hansen01 said:If you have a variation in your rpms at idle. Try turning off your ac/defroster. If that stops it. You may need a new ac compressor. If the compressor is shot it will rob power from your motor thus creating the over/ under idle.
Lol. The one thing I don't like about these cars!.. One little vacuum leak can cause all kinds of problems!..ColeJohnson said:I fixed it. Found a vacuum leak finally. Replaced the hose and purrs like a kitten now.
Glad I could be of assistance.ColeJohnson said:I fixed it. Found a vacuum leak finally. Replaced the hose and purrs like a kitten now.
