Valve clearance - Mustang Evolution
Old 02-03-2012, 07:01 PM   #1
t0t4lbl4ck0ut's Avatar
Valve clearance
Im looking at doing a set of mhs stage 3 pi heads and stage 3 blower cams and I started thinking that I'm not really sure what needs to be done to the pistons and overall motor to allow for around stock compression. I know about fly cutting pistons but that's about all I know of to help clearance. Id like to stay around 9.5 compression but like I said I'm not sure what all is needed. I plan on doing a kenne bell 2.6 around this time next year and will be running a minimum of 15 psi. But I really don't wanna get to that point and have to build the motor AGAIN
t0t4lbl4ck0ut is offline   Reply With Quote
Old 02-04-2012, 03:08 AM   #2
Region: Alaska
Maybe contact the cam manufacture and ask them if they had any problems using there cams on stock engine. You can also look at getting new pistons with valve reliefs in them.
91redfox is offline   Reply With Quote
pcv valve Berbantor 1996-2004 Mustang GT 11 01-27-2012 06:32 AM
Egr valve Matt5.0 1979-1995 Mustang GT 5 01-02-2012 09:15 PM
Valve covers!!! Coreyw428 1996-2004 Mustang GT 22 12-12-2011 10:53 AM
valve cover gasket..... rinfield2004 SVT Mustang 4 12-09-2011 12:43 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
07:20 PM
