RPM's are high?! - Mustang Evolution
Old 02-05-2012, 01:48 AM   #1
Mustang_Madness's Avatar
RPM's are high?!
I just cleaned my K&N CAI as well as cleaned the MAF, but Now my car idles at 1500 rpms! They Were at 500! I don't know what to do...
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-05-2012, 02:09 AM   #2
irishn8's Avatar
U remembered to plug both connections into the maf? Can't really imagine how the maf would affect the rpms though. Did u bump ur iac?
Old 02-05-2012, 03:03 AM   #3
Iac? And i remembered to plug Everything in. Yesterday, i ran quite a bit of seafoam through the intake vacuum line and it seemed to run Better after that. And then today, i cleaned those two things, and i noticed the rpms were idling at 1500. Towards the end of the day they dropped to about 1000 though!
Old 02-05-2012, 03:08 AM   #4
irishn8's Avatar
Idle air control by the plenum. How long did you run it?
Old 02-05-2012, 11:30 AM   #5
Re: RPM's are high?!
It could also be a vac leak or tps and one time my car was shooting to 3000 rpm and it was because a piece of gasket got stuck under my butterfly
l2plagears is offline   Reply With Quote
Old 02-05-2012, 11:30 AM   #6
I ran the car collectively about an hour. and by the end of the day it was at 1000 rpms...
Old 02-05-2012, 12:03 PM   #7
PonyBoyV6's Avatar
Mine idles about 1250 when i start it, it drops to 1000 after a few seconds, then after i've been driving for a bit it idles down to maybe 700/750 so that sounds pretty normal (1000) to me. But maybe mines messed up too. Lol
PonyBoyV6 is offline   Reply With Quote
Old 02-05-2012, 04:38 PM   #8
irishn8's Avatar
Well mine starts at 1k rpm and drops to 800-900 so maybe it has to do with your temperature sensor?
Old 02-05-2012, 04:40 PM   #9
I already Just got that replaced.. i don't know what to do guys... I'm thinking of selling the car..
Old 02-05-2012, 04:43 PM   #10
irishn8's Avatar
Try adjusting ur IAC
Old 02-05-2012, 05:38 PM   #11
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
U sure it's not the tps? My fox did this once, idled at like 2k then lowered to 1500. Is your tps adjustable?
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 02-05-2012, 05:53 PM   #12
Berbantor's Avatar
I have a code p1125 tps intermediate. It does it sometimes went threw 5 of them Still does it. It will go up to 1500rpms at a red light and Stay like that
2001 gt, 5speed. 70mm throttle body with stackracing plenum. bbk intake, 4.10 eaton posi, short shifter, o/r side exhuast.
Berbantor is offline   Reply With Quote
Old 02-05-2012, 05:54 PM   #13
Jamesgt08's Avatar
Normal idle is around 700 to 800. I would definently check your tps(throttle position sensor)
---------- Post added at 06:54 PM ---------- Previous post was at 06:53 PM ----------
Or try the cam and crank sensors as well.
Jamesgt08 is offline   Reply With Quote
Old 02-05-2012, 06:41 PM   #14
Berbantor's Avatar
Where r the cam and crank sensors at
Old 02-05-2012, 07:48 PM   #15
Jamesgt08's Avatar
The cam sensor is behind the power steering reservoir and the crank sensor is right behind the A/c compressor.
Old 02-05-2012, 07:59 PM   #16
dmax8709's Avatar
I had my rpms idling high and i changed my tps out and everything went back to normal. My buddy had the same problem with the same fix. From what i understand that is a very common thing on the 99-04 gt.
dmax8709 is offline   Reply With Quote
Old 02-05-2012, 08:59 PM   #17
Berbantor's Avatar
Yea but i replaced it 5 times and Still getting the code p1125. But no check engine light
Old 02-05-2012, 09:07 PM   #18
dmax8709's Avatar
Maybe ur iac is bad. Do u have a diablo or sct tuner ? If so u can adjust ur rpm on it and may can find a sweet spot. Is it surging or just staying at about 1500 or 1000 rpm?
Old 02-05-2012, 10:52 PM   #19
Berbantor's Avatar
Sct. And i replaced the iac twice. It only climbs in rpms. At a red light.
Old 02-05-2012, 11:02 PM   #20
dmax8709's Avatar
Does it surge or stay at a certain rpm? Urs an auto or 5speed?
Old 02-06-2012, 07:35 AM   #21
Berbantor's Avatar
Its stays at 1500 rpms. And Its a 5 speed
Old 02-06-2012, 11:52 AM   #22
dmax8709's Avatar
Go into ur sct and check the rpm n neutral answer rpm n drive and see if they r right
---------- Post added at 11:52 AM ---------- Previous post was at 11:39 AM ----------
Maybe ur throttle is sticking...? I dunno sounds odd
Old 02-06-2012, 01:10 PM   #23
Berbantor's Avatar
Wat should they be. Cuz it doesnt happen all the time
Old 02-06-2012, 01:38 PM   #24
dmax8709's Avatar
I keep mine at about 650-720
Old 02-06-2012, 07:44 PM   #25
irishn8's Avatar
Mine will stable out at about 750
Old 02-07-2012, 09:42 PM   #26
01StangGt's Avatar
Try setting the base idle, mine kind of did the same thing when I was cleaning my tb and cai. May or may not help, hope it does
01StangGt is offline   Reply With Quote
Old 02-07-2012, 10:58 PM   #27
Berbantor's Avatar
Wats the best way to do that
Old 02-08-2012, 10:34 AM   #28
01StangGt's Avatar
Start your car, remove the vacuum line that goes to you iac, cap them off, adjust you idle to we're it is ALMOST to shut off, then uncap the line and hook it up again. Now I hope this is your problem, I did this to my 01 gt and worked like a charm, couldn't run better.
Old 02-08-2012, 11:26 AM   #29
86 muscle's Avatar
Maybe an obvious answer, clean your maf again, you could have over oiled your filter! Just use the spray!
86 muscle is offline   Reply With Quote
Old 02-08-2012, 07:27 PM   #30
I did use the spray.. I might have over sprayed it though...
---------- Post added at 08:27 PM ---------- Previous post was at 08:03 PM ----------
How do you adjust the iac??
Old 02-08-2012, 10:58 PM   #31
01StangGt's Avatar
The little screw for your idle is what you want to adjust, just unplug the vacuum line that goes to the iac. Do that and let me know what happens, eager to know if that's you problem. Any questions get at me
High pitched engine noise whine cjd_1986 2005-2010 V6 Mustang 4 01-16-2012 12:34 PM
Weird smell at high rpms? Mweigt07 2011-2014 Mustang GT 35 01-05-2012 03:38 PM
High idle Travis B 1979-1995 Mustang GT 10 12-09-2011 07:48 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 11:30 PM
11:55 AM
