fox rear end - Mustang Evolution
Old 02-05-2012, 01:40 PM   #1
04GTRed_Plague's Avatar
fox rear end
I found a fox rear end with 410s and a eaton posi for $450... anyone know if the 8.8 is interchangeable with my 04 gt?
04GTRed_Plague is offline   Reply With Quote
Old 02-05-2012, 01:42 PM   #2
deadsp0t's Avatar
Yes but it's not as wide overall
That's unimpressive
Old 02-05-2012, 04:07 PM   #3
What about the gears and the posi... will they go in my rear end?
Old 02-05-2012, 04:20 PM   #4
deadsp0t's Avatar
Yes sir
That's unimpressive
Old 02-05-2012, 04:35 PM   #5
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
They will but why not buy the gears for like 150 bucks and get the master install instead of swapping the used gears out?
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 02-05-2012, 05:18 PM   #6
Well from what i hear the eatons are nice units and they are not cheap... he is selling the whole rear for $450 and the eaton alone cost that much. He's saying that the car is a 93 but the rear come out of a newer car.. bit the 94-98 rears are still shorter than mine right?
Old 02-05-2012, 05:20 PM   #7
deadsp0t's Avatar
I think 94-04 are the same, not certain though
That's unimpressive
Old 02-05-2012, 05:20 PM   #8
And his is 31 spine... will the axles swap out too? Im just obtaining info... im not for sure gonna buy it yet
Old 02-05-2012, 05:23 PM   #9
Pete Jones
Your stock axles are 28 spline but if you swap into everything from that 8.8 yes you could IF his axle is the same width as yours and if it is the sane width just swap in the entire axle as long as it's still 5 lug.
90 LX hatchback
89 LX Notchback
Old 02-05-2012, 05:29 PM   #10
That's what i would do if i swapped the parts from his... but if it is a shorter rear the the axles wouldn't work right?
Old 02-05-2012, 05:58 PM   #11
Pete Jones
I would say no but I've never measured a foxes shafts and a newer 5 lug shaft. Just take measurements of your axle like back side of drums(or discs) to other side then measure his to be certain.
90 LX hatchback
89 LX Notchback
Old 02-05-2012, 06:43 PM   #12
I found out his is a 5 lug out of newer stang which would of been good to put on craigslist instead of saying its a fox rear but idk what year it cane out of... i have been told that the 94-98s are shorter but i have never measured one either
Old 02-09-2012, 12:31 AM   #13
32vNomad's Avatar
Fox rear end housing and 94-98 SN95's are the same in length. The axles however are longer on sn95's for the rear disks and abs. The 99-04 rear end both housing and axles are wider . The Fox or early sn95 will not work on new edge sn95's.
32vNomad is offline   Reply With Quote
Gt rear end Blackedout Pre-2005 V6 Mustang 11 01-19-2012 04:41 PM
Rear End Swap Sycopath80 2005-2010 V6 Mustang 3 12-30-2011 11:25 AM
Rear end clunk Brad.krieg SVT Mustang 3 12-08-2011 12:05 AM
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
04:50 PM
