need help bad please help - Mustang Evolution
Old 02-05-2012, 05:07 PM   #1
Codysmustang's Avatar
my car has been off the road for almost a month now. it will not accelerate at all. when start it up it is fine. but once put a load on it then it just jumps and chokes out. i don't know what to do please help
Codysmustang is offline   Reply With Quote
Old 02-05-2012, 05:24 PM   #2
Re: need help bad please help
check your fuel pressure at the shrader valve on the fuel rail. I'd say it's either your fuel pump or your frps.
Old 02-05-2012, 05:47 PM   #3
i changed out the fuel pump and filter already.. so where exactly do i need to check the fuel pressure?
Old 02-05-2012, 06:06 PM   #4
02PONY's Avatar
Sounds like fuel pressure regulator
---------- Post added at 08:06 PM ---------- Previous post was at 08:04 PM ----------
But don't think these have one any codes
02PONY is offline   Reply With Quote
Old 02-05-2012, 06:09 PM   #5
where is it exactly.. i have the all data for the car and it telling me that there is none..
Old 02-05-2012, 06:11 PM   #6
02PONY's Avatar
So no codes and it dies as soon as u press the gas?
Old 02-05-2012, 06:26 PM   #7
it has codes. last time i looked had 12. 4 for O2 sensors ( which i changed the rear 2 and the other two close to the engine i believe are wielded to the exhaust) like 2 or 4 for evap.. and then apparently there are some throttle codes to.. i can get a list
Old 02-06-2012, 05:43 AM   #8
jjsg09's Avatar
Check your CAI bolts and make sure it didn't come loose. I have a JLT CAI and when I leave my car setting for a week it loosens around the throttle body and my car does the same thing. Pretty much it just sucks in unmonitored air in and your car can't accelerate worth crap.
If that checks out to be ok I'd say fuel pressure regulator, you can find the fuel pressure check valve on the fuel rail passenger side toward the front of the engine with a plastic black cap.
Old 02-06-2012, 05:46 AM   #9
I am missing a ring around the cai after the sensor. The piece came off. And I know where talking about on fuel rail. What am I soposed to do to check the pressure and all that?
Old 02-06-2012, 05:53 AM   #10
jjsg09's Avatar
That ring is very important you need to get it back on there your probably getting too much air after that sensor. It's very important to have everything tight on a CAI.
Go to a parts store and rent a fuel pressure tester. I rent mine from Auto Zone for $160 but it's fully refunded after you bring it back. Just match the right fitting on the fuel port hook the gauge to it. Turn your stang on and it should read around 40 for a good read out. If its surging up and down on the gauge it's probably your FPR going bad.
Old 02-06-2012, 07:39 AM   #11
ok will do.. and if it is the fpr where is it located at so i can replace it?
Old 02-06-2012, 12:47 PM   #12
jjsg09's Avatar
I'm doing some research on a fpr on the 4.6 and there isn't one......huh. Well there is a fuel relay switch that can be going bad.
Old 02-06-2012, 12:59 PM   #13
Gster's Avatar
That's your problem fix your CAI .
Gster is offline   Reply With Quote
Old 02-06-2012, 01:02 PM   #14
deadsp0t's Avatar
Yes.. Cover all the basic stuff before throwing unnecessary parts at it
That's unimpressive
Old 02-06-2012, 01:44 PM   #15
Will do y'all thank you so much for the help.. Will the added air cause the car to throw throttle codes? I gonna try to get that list of codes up so can see bout fixing it
Old 02-06-2012, 03:11 PM   #16
jjsg09's Avatar
Oh yea it did it to mine when my CAI came loose.
Old 02-06-2012, 03:25 PM   #17
Nice thank y'all I doin the work later today so I will let u no
Old 02-06-2012, 06:17 PM   #18
ok so put the clamp on and it runs! now it still kinda chokes out so still gonna check the fuel pressure relay.. but it could also be that the battery was to low.. had to jump it off.. but i will charge it over night then tomorrow i will take the battery completely out to clear all the codes. hopefully that gets rid of the throttle codes and maybe even the O2 codes as well. i will post the codes on here in the next hour. see what can do.. i really want y'all to know i really appreciate everything y'all have done to help me. THANK YOU SO MUCH
Old 02-07-2012, 07:03 PM   #19
jjsg09's Avatar
No problem bud just let us know what happens. Hope taking the battery out will clear up the rest of the problems.
Old 02-11-2012, 03:25 PM   #20
ok so i got the thing running and i think the filter needed to be changed.. i ran the car without it and did great for a bit.. then choked out. the problem is that i bout the car with the k&n cai on it. the base seems to have a 6" on it. i looked at the k&n at the car shops and auto zone and don't look the same.. and spectre filters go to 4".. so what now?
Signs of a bad oxygen sensor 04machazblue 1979-1995 Mustang GT 33 01-24-2012 04:10 PM
Bad Lifters? Please help.. FORDGT14 1996-2004 Mustang GT 0 01-22-2012 03:03 PM
Bad Fuel Filter? chrissiesstang Pre-2005 V6 Mustang 4 11-09-2011 04:51 AM
96 SVT Cobra appears Superchip is bad opinions on my options please Spiney SVT Mustang 15 11-07-2011 07:34 AM
Bad luck... Blackedout Pre-2005 V6 Mustang 20 07-29-2011 07:50 AM
09:42 PM
