A/C Not Working!!! - Mustang Evolution
Old 02-06-2012, 12:16 AM   #1
FORDGT14's Avatar
A/C Not Working!!!
The A/C worked fine and then suddenly started surging the idle and going from 1k rpm down to 500 rpm and back up to 1k agian. It does this over and over and the air doesnt get cold. The compressor will kick on and run with cold air when i disconect/reconnect the battery and reset the car, but after the compressor kicks off once, it never comes back on..just starts surging the idle until i turn the A/C off and disconect/reconnect the battery again to reset it.. I was told it could be the "CCRM" (Constant Control Relay Module) but i when i put the new one on, it kept doing the same thing...im lost guys, please help!
Summers coming and Im in Arizona..im gona sweat my *** off if i dont get this fixed
HELP!!!
---------- Post added at 02:16 AM ---------- Previous post was at 02:14 AM ----------
The car is a 1999 Mustang Gt with a 4.6l 2V engine by the way
Thanks for any help!
FORDGT14 is offline   Reply With Quote
Old 02-06-2012, 12:41 AM   #2
irishn8's Avatar
I don't really have an answer for you, but the first thing I would do is make sure the A/C system is fully charged. You can go to any parts store and get a gauge for cheap. If its low, have it checked out for leaks.
Old 02-06-2012, 10:13 PM   #3
Black99Snake's Avatar
Check all your vaccume lines they control everything engine, ac, heat fans.
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 02-06-2012, 11:28 PM   #4
AgentOrange's Avatar
Re: A/C Not Working!!!
I have to +1 both of the previous replies. Does the compressor make any noise when it is running? The refrigerant carries the lubrication for your compressor... Very strange issue.
AgentOrange is offline   Reply With Quote
Old 02-07-2012, 04:31 PM   #5
FORDGT14's Avatar
No the compressor sounds normal when its on..idk wat the hell to think
A/C Question FORDGT14 1996-2004 Mustang GT 5 01-13-2012 03:54 PM
A/c Meansaleen 1979-1995 Mustang GT 4 09-17-2011 02:50 PM
Head unit not working..... mcvicar04 1996-2004 Mustang GT 20 07-29-2011 09:08 AM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
02:43 PM
