T56 to auto - Mustang Evolution
Old 02-06-2012, 10:05 AM   #1
bostang99's Avatar
T56 to auto
I want to remove my T56 and install an auto for street/strip use. What can expect in the exchange? For track use I need a 450-500 hp capable tranny. Who should i look at? Probably gonna run a stall and line lock.
bostang99 is offline   Reply With Quote
Old 02-06-2012, 10:31 AM   #2
Black99Snake's Avatar
I posted a reply a day or two ago for someone else if you want to check it out. I've done the research for I will be doin the same next year. It's a lot to type so the easiest way would be scroll down a little. If you got any more questions just ask. Hope it helps
---------- Post added at 05:31 PM ---------- Previous post was at 05:28 PM ----------
The post is labeled 5 speed to auto swap
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 02-08-2012, 07:25 AM   #3
Re: T56 to auto
call darrin at bc auto to set you up with a tranny and conveter..he can also set you up with all the parts needed to do the conversion...
need tranny,cross member,drive shaft,auto computer,auto harness,shifter,auto bezel or use your manual boost
slow02gt is offline   Reply With Quote
any auto guys wish was manual? wnt2gofst 2011-2014 Mustang GT 39 10-22-2011 03:26 PM
dragging with auto? 5.slow At the Track 14 09-11-2011 10:20 AM
» Members Mustangs
Rousey
jdg1102
Sal
KSN95
Add your Mustang
11:58 AM
