upr x pipe leak - Mustang Evolution
Old 02-06-2012, 05:17 PM   #1
04GTRed_Plague's Avatar
upr x pipe leak
I installed my upr the other day and everything was pretty straight forward ... i used the flange provided and bought a new passenger side gasket but i have a leak on the passenger side on the back of the pipe where it bolts to tje cat back. I have loosened it and moved it and made sure it was tight and it still leaks. Any suggestions?
04GTRed_Plague is offline   Reply With Quote
Old 02-07-2012, 10:09 AM   #2
Anyone?
Old 02-07-2012, 10:17 AM   #3
jjsg09's Avatar
Just asking, your sure that's where the leak is?
Old 02-07-2012, 11:09 AM   #4
Yep... i xan feel the exhaust coming out right there
Old 02-07-2012, 10:31 PM   #5
Is it o/r?
04vertgt is offline   Reply With Quote
Old 02-07-2012, 11:55 PM   #6
Brad.krieg's Avatar
Send a message via Yahoo to Brad.krieg Send a message via Skype™ to Brad.krieg
Thats the problem sometimes with these aftermarket mid pipes, some just dont fit right.
I'm sure you can fix it, i have no idea how tho without welding. Keep us updated, i think this is a common problem.
Brad.krieg is offline   Reply With Quote
Old 02-08-2012, 12:50 PM   #7
Re: upr x pipe leak
I got it to stop .. i used some exhaust joint sealer and rotated the flange a little and carefully tightened it back and it stopped. Idk how much the sealer helped or if it was adjusting the flange a little? And yes it is off road
Old 02-08-2012, 06:18 PM   #8
Brad.krieg's Avatar
Hmm, yeah sometimes those flanges are tricky. I think mines popping a slight leak it hangs lower than the stock midpipe. Everytime i go over a speed bump its scarping. Maybe i'll try the exact same thing. What kind of sealer are you using?
Old 02-08-2012, 08:12 PM   #9
Re: upr x pipe leak
What brand is ur mid pipe? I have the upr and they are supposed to tuck under the car better than most others .. thats what i hear anyway. My car is lowered and i still dont scrape mine. It was something i grabed at advanced auto fpr like $7... exhaust joint sealer... dont remember the brand and im not at home right now
Old 02-08-2012, 10:43 PM   #10
Brad.krieg's Avatar
Oh ok. I have a dr gas o/r x. My car is really low anyway tho there is only like 5 inches from the ground to the car. The pipe tucked up really nice without the MILS, but it kept throwing the codes so i put them back in.
Call me crazy but it feels like i have more power anyway with the mils on, maybe its the angle that the exhaust flows through the pipe or something...
Old 02-09-2012, 09:53 AM   #11
Thats about the clearance i have.... im lowered with the sportlines. I take it really easy over speed bumps but i did that b4 i lowered... having more power with the mils makes sense.... they tricking the computer into thinking the cats are there so ur computer is able to adjust. Thats my theory anyway..haha
Old 02-09-2012, 01:02 PM   #12
Brad.krieg's Avatar
Ah good point. It probably starts running in some sort of default mode which i'm assuming would be super rich.... Didn't even think about that. Good one.
Old 02-09-2012, 01:30 PM   #13
Yea its prob running rich without them in... but ur scraping with them in?
Old 02-09-2012, 05:56 PM   #14
Brad.krieg's Avatar
Oh yeah, i lost about an inch to those things, scrape every time. Not too bad tho. As long as i dont bang it i'm good. The snail crawl accross bumps is super annoying.. I guess its a small price to pay for good looks and handling.
Old 02-09-2012, 07:10 PM   #15
Im assuming u dont have a tuner since ur using mils? I just cut the rear sensors off and snipped the wires on the sensor. I left enough wire so i can splice the wires if need be later.... just saying if the scrapping gets to annoying
Old 02-09-2012, 07:55 PM   #16
Brad.krieg's Avatar
i actually have a tuner, use it all the time. I Haven't heard of programming your computer to the x pipe so it doesnt throw codes. Is that possible?
Old 02-10-2012, 08:46 AM   #17
Yea man... whatever company u have ur tuner with can reprogram ur tunes with the off road pipe and it will turn ur rear sensors off
Old 02-10-2012, 09:39 AM   #18
Brad.krieg's Avatar
Hmm, interesting. I haven't seen that option on the strategy tune. I think i'll take your advice and give em a ring.
Thanks.
---------- Post added at 11:39 AM ---------- Previous post was at 11:34 AM ----------
Damn man, if that works, pulling that damn pipe off again is going to be a b*itch! I've worked on that car a lot in the last couple weeks... glad I don't do it for a living.
Old 02-10-2012, 12:29 PM   #19
Yea give em a call and they will help u out... there isnt a way to get to the mils without taking the pipe off? That sucks to keep taking it on and off
Old 02-10-2012, 06:58 PM   #20
Brad.krieg's Avatar
Well, I could but I have to take it almost completely off to reposition it for better clearance. I think imma sit on that for a while until it really starts bothering me.
I just did a brake job on this thing and I couldnt get the damn rotors off, took me two days of beating the sh*t outta them.. i was about to take the blow torch to it until i figured out a trick. Then after all that, i put everything back together just to find out American muscle had send me the wrong size rotors haha.
Old 02-10-2012, 10:13 PM   #21
LAS97GT's Avatar
I had same issue. Just turned off cats and applied tune. Usually it's dwn stream sens that need input for emmisions & fuel apps. Caused by high flow exceeding o2s cap.
---Las97GT
Old 02-10-2012, 10:16 PM   #22
Wow dude thats sucks! I would leave it alone too! Haha
Old 02-10-2012, 11:16 PM   #23
Brad.krieg's Avatar
Re: upr x pipe leak
Thanks for that info though! It was really helpful. I don"t know why I didn't think of that.
Old 02-20-2012, 12:01 AM   #24
LAS97GT's Avatar
Re: upr x pipe leak
Hello, about the leaking exhaust:
The DIY leaking exhaust check is done at night with a flashlight!!
LOL, that's right at night with a flashlight. Here's what you do, wait till dark, crank up the motor, get your clear lens flashlight, flash it down the left and right side of the manifolds, observe for smoke. Before the exhaust reaches the cats, its smoke. Found out that my exhaust was damaged by same technique. My cats were getting banged on the street a lot becuase they were about 2-3 inches off the floor, bent them beyond repair causing exhaust leaks. That led to smoke entering the cabin via my Cobra-R hood which lets you sniff the engine while you hear it. True.
Reality Check:
If you must replace the exhaust system, minus the muffler, get a performance model, thery are usually cheaper than stock. Doing this will add an upgrade and improve performance.
let me know what you decided, and if the check worked for you. It worked for me.
---Las97GT
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Upr o/r x pipe 04vertgt 1996-2004 Mustang GT 5 01-03-2012 07:09 PM
3.8 Dual Exhaust ssaleen1981 Pre-2005 V6 Mustang 27 12-18-2011 06:43 AM
X pipe vs H pipe ercolanom1 General Mustang Discussion 3 10-21-2011 02:09 PM
Axle-backs now...X pipe and more later? illestdomer2005 2011-2014 V6 Mustang 5 08-07-2011 06:55 PM
06:53 AM
