oil leak from filter housing - Mustang Evolution
Old 02-06-2012, 09:14 PM   #1
86 muscle's Avatar
Im sure some of yall have had this problem, its leaking from where the oil filter screws onto the block, ive got a Lincoln that has the same leak. Any help would be awesome
86 muscle is offline   Reply With Quote
Old 02-06-2012, 11:06 PM   #2
Black99Snake's Avatar
It's leaking from the set screw mines doin it I pulled it out n put some loc tight sealant on it n it leaks worse so don't pull it out. I've been told that you have to replace that screw to stop the leaking. I haven't yet so I don't know. Let us know how it goes
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 02-07-2012, 09:37 PM   #3
01StangGt's Avatar
Try checking the gasket, mine is leaking from the gasket, it's called an oil filter adapter gasket, like 11 bucks at pep boys. Will need to pull the lower radiator hose so I would do a flush on the radiator when doing the gasket, just my opinion.
01StangGt is offline   Reply With Quote
Old 02-08-2012, 11:16 AM   #4
86 muscle's Avatar
That's what it is. Ill get it this weekend, although I dont have a pepboys around here ill just go to the dealer! I get a nice little discount from then anyways!
Oil guage problem Blackedout Pre-2005 V6 Mustang 19 02-12-2012 05:44 AM
I'm pretty sure my oil pump went out wc3john 1979-1995 Mustang GT 9 02-08-2012 11:26 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 02:52 PM
Off Topic Question - Oil Weight illestdomer2005 Pre-2005 V6 Mustang 7 09-09-2011 10:26 AM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 02:17 PM
02:00 PM
