PCV Valve - Mustang Evolution
Old 02-07-2012, 11:08 AM   #1
jjsg09's Avatar
PCV Valve
Ok I changed my PCV valve in my 02 GT about 5 months ago it was bad. Ok now i looked at it yesterday with some good light and there is oil sputtered all around it and oil puddles on the valve cover. I don't think it could be the PCV valve doing it and the valve has to be screwed in a fitting that locks it in......so I need some advice. I will try to post some pics of it today
Old 02-07-2012, 02:02 PM   #2
Albo22's Avatar
I have a 2000gt and my cai actually pushed my pcv valve halfway out, condensation was all over the valve cover, i bought a shorter in height pcv valve and put it in and it cleared the cai, no more condesation after i did that, idk if thatll help though
Albo22 is offline   Reply With Quote
Old 02-08-2012, 07:12 AM   #3
jjsg09's Avatar
My CAI isn't touching it at all. The hose that goes from the PVC to the intake stays collapsed while the car is running and I think that might have something to do with it.
Old 02-08-2012, 07:15 AM   #4
Las0mbra's Avatar
Hmm, maybe you could go to autozone and get them to cut you a section of rubber fuel line? That stuff won't collapse under vacuum and should work fine, well, as long as the fittings are the correct size.
95 5.0 pcv valve ? plz help asap durtyred69 1979-1995 Mustang GT 5 02-02-2012 12:04 AM
pcv valve Berbantor 1996-2004 Mustang GT 11 01-27-2012 07:32 AM
PCV Hose jjsg09 1996-2004 Mustang GT 5 01-17-2012 11:21 PM
Pcv valve Jpstang 1979-1995 Mustang GT 5 11-26-2011 10:55 AM
PCV Valve MustangGT02 1996-2004 Mustang GT 1 08-27-2011 09:46 AM
09:29 PM
