Chopping springs - Mustang Evolution
Old 02-08-2012, 12:07 PM   #1
Mile high JDF's Avatar
Chopping springs
So I'm planning on chopping my springs here in a couple days, I was wondering how much of the coil do I need to cut off to get about a 1.5" drop in front and roughly the same in back?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-08-2012, 12:11 PM   #2
03GT88's Avatar
I've heard you only cut half a rung each time until you get the drop you want.
03GT88 is offline   Reply With Quote
Old 02-08-2012, 12:11 PM   #3
01StangGt's Avatar
I would suggest NOT cutting them, do it wrong your going to end up buying new ones, save the hassle and they really aren't to expensive. BUT that's just my opinion.
01StangGt is offline   Reply With Quote
Old 02-08-2012, 12:36 PM   #4
That's what I figured I would do.
---------- Post added at 06:36 PM ---------- Previous post was at 06:33 PM ----------
I'm going to use a cut off wheel, make sure to deburr any edges and primer the end I cut off. I haven't heard of anybody messing anything up with them. I have the money to buy new springs, however, if I cut the springs then that will allow me to buy something else like subframe connectors.
Old 02-08-2012, 05:50 PM   #5
Re: Chopping springs
It's not so much doing the cutting wrong as it is changing the overall load characteristics of the spring. Cutting is the best way, NO heating up the springs.
The stock springs are linear, meaning they retain the same rate throughout the characteristic band of the spring. When being pushed they simply apply the same rate as just cruising down the road. When you cut the spring, you change that rate which the shocks and rest of suspension are mated to...it could cause other suspension pieces to wear quicker. Your camber might be altered as well.
Most guys will cut their springs as a temporary look until they by progressive lowering springs. I know a few guys who have had their cut ones in for years and haven't had major problems, just a stiffer ride and some grinding/noise.
There is a rough ratio out there but I can't remember where I saw it..another forum years ago. I'd say your best bet is to cut one coil, then drop the car and see where it sits. I think cobra guys were cutting 1.5 coils to drop theirs ~2".
Keep in mind the rears probably need slightly more to even the car out..unless you're going for a raked look.
Old 02-08-2012, 06:04 PM   #6
I'm doing it as temporary thing. I'm going to order H&R race springs sometime this year, but the stock stance is really mugging me right now so I don't mind cutting them. My tires are pretty bad already so I'm not worried about camber wear. My goal this year is suspension components, so if they break then I'll replace them as they do.
Old 02-08-2012, 06:14 PM   #7
Topless04GT's Avatar
1/2 rotation until its enough.
I however and strongly against this and everytime someone gets ready to do this. I will keep myself from ranting in this thread though. I will leave my insight and leave the common sense aspect alone. thanks
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 02-08-2012, 06:16 PM   #8
I'd like to hear what you want to say if you'd like to pm me
Lowering Springs jjsg09 1996-2004 Mustang GT 14 02-06-2012 07:11 AM
Springs Mile high JDF 1996-2004 Mustang GT 2 01-03-2012 02:15 PM
55D Springs on Brembo Brake Mustangs 201150300A 2011-2014 Mustang GT 0 12-13-2011 06:16 PM
Lowering springs JGeezy44 General Mustang Discussion 5 10-06-2011 03:31 PM
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 10:32 AM
07:00 PM
