Ball joints - Mustang Evolution
Old 02-10-2012, 07:28 PM   #1
Gt7
Gt7's Avatar
Ball joints
Hi I just replaced the ball joint on my car plaining on replacing the left side but my mustang is now sitting side ways from the side I changed out the ball joint? I toke out completely the spring idk if this is normal if someone can let me know I would I appreciate it... Thanks
Gt7 is offline   Reply With Quote
Old 02-10-2012, 07:31 PM   #2
Cobrarunnin9s's Avatar
Re: Ball joints
Did you put the spring back in exactly the way it came out? If not, it will definitely affect your ride height.
Cobrarunnin9s is offline   Reply With Quote
Old 02-10-2012, 07:38 PM   #3
Gt7
Gt7's Avatar
Yea I went in differently only because I didn't have a internal coil spring compressor or I didn't secure it b4 taking it out... It was the first time swapping em out
Old 02-10-2012, 09:30 PM   #4
Re: Ball joints
You don't have to have a spring compressor but it does make it easier. It definitely helps to have a buddy give you hand installing them to make it sure the spring says in the pocket while you hook up the ball joint in the spindle as well.
Old 02-10-2012, 09:38 PM   #5
CrimsonGT's Avatar
How on gods green earth did you get the spindle off the ball joint? I've been trying for two weeks now using a pickle fork and lots of assorted hammers not even a wiggle!!!
I spent 2 hours straight hitting the pickle fork with a 15lb sledge today and I swear I heard it laughing at me
If anyone knows what I'm doing wrong I'd love to be enlightened
CrimsonGT is offline   Reply With Quote
Old 02-10-2012, 09:43 PM   #6
Re: Ball joints
All I do is loosen the ball joint nut up about 1/4 in off the spindle, than take a sledge and smack the spindle right where the taper on the ball joint is and it will pop loose after a few good hits most of the time.
Old 02-10-2012, 09:47 PM   #7
CrimsonGT's Avatar
Yeah I tried similar things to that the first go around and it didn't move but I'll give it a shot tomorrow thank you for the suggestion any help is greatly appreciated at this point
Old 02-10-2012, 09:48 PM   #8
Re: Ball joints
Is the spindle still torqued to the strut?
Old 02-10-2012, 09:54 PM   #9
CrimsonGT's Avatar
No everything is disconnected and off the car except the spindle and the joint to the tie rod which also will not budge
---------- Post added at 11:54 PM ---------- Previous post was at 11:49 PM ----------
It's kinda sad cause it's my daily driver and so when I fail at getting it off I have to put everything back on and try again the next day
I can officially rebuild my entire suspension in about 15 minutes now
Other than the spindle and ball joints
But considering I've been doing this for about two weeks now I guess it's good practice
Old 02-11-2012, 06:06 AM   #10
Gt7
Gt7's Avatar
Oh I took off the ball joint with a 20 ton jack only quick way and I did have help pressing back the ball joint someone I knew had the kit but the spring gave me the most problems...
Old 02-11-2012, 09:38 AM   #11
CrimsonGT's Avatar
Can you elaborate on this a little bit for me please?
Old 02-11-2012, 01:00 PM   #12
Re: Ball joints
The ball joint nut is the first thing I loosen and separate, then you take everything loose from the spindle afterwards.
Old 02-11-2012, 07:08 PM   #13
Gt7
Gt7's Avatar
Well what I did was disconnect everything ball joint from the caliper sway bar links tire rod all that then I took off the a arm or control arm whatever u want to call it off... With the ball joint still on it... Then I took it to a guys shop and he has the press with a jack basically just put a piece of the ball joint press kit under the balljoint too allow it to go down but still hold the a arm around and put all the way weight on top of the ball joint and like magic it came out... The hitting thing takes a long time and I even banged up my finger doing it but that was the simples thing about this job with right tools...
Old 02-12-2012, 08:33 AM   #14
Project Pony's Avatar
I rented a ball joint press from advanced auto. Worked like a charm. It cost a 100 bucks but I got all of it back when I returned it. Took about 15 minutes per side.
[SIGPIC][/SIGPIC]
Old 02-12-2012, 09:17 AM   #15
CrimsonGT's Avatar
I did this too but I couldn't get the press on the ball joint with the spindle still on
Old 02-12-2012, 10:54 AM   #16
Re: Ball joints
You need to break the ball joint nut loose first BEFORE anything else same with the tie rod nut and separate the tapers and then you can take everything else loose from the spindle and control arm.
Steeda X2 ball joints jhagan1980 1979-1995 Mustang GT 23 02-05-2012 04:35 PM
Paint shifter ball Silversky545 2005-2010 Mustang GT 19 01-28-2012 07:56 PM
Steeda x2 Ball Joints 01mineralgreyv8 1996-2004 Mustang GT 11 01-14-2012 10:49 PM
Squeaky suspension deadsp0t 1979-1995 Mustang GT 20 01-12-2012 01:22 PM
new shifter handle and white shift ball? robertoortiz85 1996-2004 Mustang GT 5 12-13-2011 02:40 PM
12:05 PM
