Intake Manifold - Mustang Evolution
Old 02-11-2012, 08:08 PM   #1
Mustang_Madness's Avatar
Intake Manifold
So i just took out a 95' Ford Thunderbird Intake Manifold, to swap with my plastic intake that has a leak. The engines are both 4.6's and my engines a 98, the thunderbirds a 95. Is that ok to do? Its a metal or aluminum intake, so I want to know if its smart to swap, along with the gaskets and all that... Like it will work when i do it, instead of finding out that something wouldn't match up after swapping it all.
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-11-2012, 09:57 PM   #2
Re: Intake Manifold
I really need to know this guys! common! I have the intake in front of me! i just want to know if it will work before I clean it out and use it!
Old 02-11-2012, 10:22 PM   #3
irishn8's Avatar
I would compare it to the other one and match the holes on the bottom.
Old 02-11-2012, 10:37 PM   #4
Re: Intake Manifold
That would mean taking off the intake on my mustang right now huh... damn. I was hoping to know Before I swapped it
Old 02-11-2012, 10:40 PM   #5
irishn8's Avatar
Sorry I don't have a better answer for ya. Maybe someone will chime in who knows. At least you can compare the top without removing.
Old 02-11-2012, 10:47 PM   #6
Re: Intake Manifold
It looks exactly the same! nothing different!
Old 02-12-2012, 12:20 AM   #7
However, the throttlebody that i have isnt in the same place that i pulled the other out off. Nor the IAC
Old 02-24-2012, 09:53 PM   #8
LAS97GT's Avatar
Re: Intake Manifold
Look, Ford made it a point to create cars of same model years from different manufacturing plants that engine components dont fit each other. Go figure. It's hard to swap parts. Good luck, its hard to give an answer. Usually, us folks leave it up to the folks that got the specs from FORD. I.e. the folks you buy parts from like AM, and so on.
---Las97GT
Old 02-25-2012, 07:20 AM   #9
clark98gt's Avatar
Re: Intake Manifold
I havent seen anything listing the any of the car 4.6 intakes being different besides P.I. to non PI so the intake itself should be fine. You should be able to swap your mustang thtottle body and elbow to the new intake. It is a rubber gasket under the elbow so you may be able to re use that as long as it looks ok.
---------- Post added at 09:20 AM ---------- Previous post was at 09:16 AM ----------
As far as I know the only manufacturing differences that are anything "major" between manufacturing plants is the romeo and windsor engines have different valve covers(more or less bolts) and differences in main bearings. I wouldnt be surprised if crown vics, thunderbirds, and other 4.6 powered cars may have the throtttle body facing opposite ways for different applications but the intake itself should be the same.
1998 Gt- current progress
Engine back in car some reassembly required
clark98gt is offline   Reply With Quote
Intake Manifold Gasket (Continuation) Mustang1804 1996-2004 Mustang GT 4 12-20-2011 02:09 PM
Intake Manifold Gasket Mustang1804 1996-2004 Mustang GT 9 11-29-2011 10:11 AM
Ford racing intake manifold 2002Gt 1996-2004 Mustang GT 5 11-15-2011 10:40 AM
Cracked Intake manifold... bobsurvives 1996-2004 Mustang GT 7 10-16-2011 12:03 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
01:13 PM
